Mid Afternoon Dropouts
- Mid Afternoon Dropouts
Re: Mid Afternoon Dropouts
30-08-2014 2:28 PM
Sorry I did not get back to you, however I see other members have helped out...
[@Maurice - no additional information is a hijack - talking of which you might find the following useful]
...I have been rather distracted by a similar sounding problem with another user - a line which to all intents and purposes is sound, but has unexplained disconnections. Can you please check out the following for me please, assuming you are using the TG582n router supplied by PlusNet...
1. The firmware version - see http://192.168.1.254/cgi/b/info/?be=0&l0=1&l1=0 - you will need to log in
2. Examine the FULL router log (category = ALL) after a disconnect - see http://192.168.1.254/cgi/b/events/?be=0&l0=1&l1=2
Look for (a) Time stamps of 1st Jan (b) The text "Kernel Warm Restart"
If this is NOT the TG582n then this has no bearing on matters, however a "fuller" log listing would be useful - there might be more logging options you can turn on, for example xDSL, errors, warnings, info...
The next step might be to look at more detailed monitoring, depending upon your modem and computer (hopefully for what I have in mind, not a Mac?).
Kevin
30-08-2014 2:49 PM
As far as the dowload speeds are concerned, if the sync speed is now back to your near normal speed, it's probably just a case of your Current Line speed updating to 11.7 to match the BT IP Profile.
30-08-2014 3:48 PM
Quote from: PhyllisTyne Upstream Downstream
Current Rate (Kbps) 1128 13344
Max Rate (Kbps) 1128 13488
SNR Margin (dB) 6.8 5.3
Line Attenuation (dB) 15.9 31.6
Errors (Pkts) 0 0
Current Rate (Kbps) 1116 11776
Max Rate (Kbps) 1116 13600
SNR Margin (dB) 6.8 6.8
Errors (Pkts) 0 0
Current Rate (Kbps) 1100 13172
Max Rate (Kbps) 1100 13452
SNR Margin (dB) 6.9 6.2
Errors (Pkts) 0 0
Current Rate (Kbps) 1112 13360
Max Rate (Kbps) 1116 13548
SNR Margin (dB) 6.6 6.2
Errors (Pkts) 0 0
Hi Dan,
Is this statement in reference to PRIOR to 20th Aug when Phyllis raised the thread?
Quote from: Dan Your line has been running at 3DB SNR which is quite low for your line, I can also see quite a lot of errors after looking back a week or so. Recently over the last few days DLM has kicked in and increased the SNR to 6.8 which as far as I can see seems to have stablised the line.
The stats provided all indicate a SNRM circa 6dB, which if the reported 3dB target was as recently as the 28th then some thing seems a bit strange here.
The connection graph shows several days continuous connectivity post 20th Aug, which does not tie in with the user's perceptions.
Back to Phyllis,
Exactly what do you see when you "perceive" the connection has dropped please? The reason for asking is that the RADIUS connection log shows several days without a disconnect and (unless the router log is filtered) it only shows PPP session status, which IIRC at that time there were wide spread BT connectivity issues.
Even though your line is synching below expectations, may be we should just sit and watch this one for a while?
Kevin
30-08-2014 3:50 PM
it is currently a TP-Link D-W8970 which until recently had been solid. I have given up with the PN routers as they don't seem to be able to cope with the number of wireless attached devices I have without bombing out.
A previous TP-Link TD-8817 attached to a Netgear R7000 was also rock solid but the R7000 wireless was unstable so that had to go.
I will post a debug error log which seems to be the most detailed if it drops again.
There is an error in the log at the moment but the date stamp suggests that is part of the reboot process this morning. I cleared the log before reboot.
The log around the eror is below if its any use bu the connection has been stable with no errors or warnings since this morning.
Thanks for your help.
PT
124 1970-01-01 00:01:18 PPP Information ppp1 rcvd [IPCP ConfAck id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10>
125 1970-01-01 00:01:18 PPP Information ppp1 sent [IPCP ConfReq id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10>
126 1970-01-01 00:01:18 PPP Information ppp1 rcvd [IPCP ConfNak id=0x2 <addr 81.174.240.75> <ms-dns1 212.159.6.9> <ms-dns2 212.159.6.10>
127 1970-01-01 00:01:18 PPP Information ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
128 1970-01-01 00:01:18 PPP Information ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
129 1970-01-01 00:01:18 PPP Information ppp1 sent [IPCP ConfAck id=0x5d <addr 195.166.128.191>]
130 1970-01-01 00:01:18 PPP Information ppp1 rcvd [IPCP ConfReq id=0x5d <addr 195.166.128.191>] 00 00 00 00 00 00 00 00 00 00 00 00 00 0
131 1970-01-01 00:01:18 PPP Information ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
132 1970-01-01 00:01:18 PPP Information ppp1 rcvd [CHAP Success id=0xf5 ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
133 1970-01-01 00:01:17 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x26aa6c63] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
134 1970-01-01 00:01:17 PPP Information ppp1 sent [CHAP Response id=0xf5 <1913b4b7603debba01032d53310d39ae>, name = "xxxxxx@plusdsl.ne
135 1970-01-01 00:01:17 PPP Information ppp1 rcvd [CHAP Challenge id=0xf5 <de54a94d7f01ed5a7b3ba066341f39ec>, name = "PTN-AG02"] 00 00 0
136 1970-01-01 00:01:17 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0xc2479e8f]
137 1970-01-01 00:01:17 PPP Information ppp1 rcvd [LCP ConfAck id=0x2 <mru 1480> <magic 0xc2479e8f>] 00 00 00 00 00 00 00 00 00 00 00 00
138 1970-01-01 00:01:17 PPP Information ppp1 sent [LCP ConfAck id=0x39 <mru 32725> <auth chap MD5> <magic 0x26aa6c63>]
139 1970-01-01 00:01:17 PPP Information ppp1 sent [LCP ConfReq id=0x2 <mru 1480> <magic 0xc2479e8f>]
140 1970-01-01 00:01:17 PPP Warning ppp1 LCP down
141 1970-01-01 00:01:17 PPP Error ppp1 LCP down
142 1970-01-01 00:01:17 PPP Information ppp1 rcvd [LCP ConfReq id=0x39 <mru 32725> <auth chap MD5> <magic 0x26aa6c63>] 00 00 00 00 00 00
143 1970-01-01 00:01:16 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x618438ed] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
144 1970-01-01 00:01:16 PPP Information ppp1 sent [CHAP Response id=0x1 <e6914777c637c6219966c23ddd615fc2>, name = "xxxxxx
145 1970-01-01 00:01:16 PPP Information ppp1 rcvd [CHAP Challenge id=0x1 <af649f3bc2d79cc124695f72f2d45b35>, name = "bras-red12.pe"] af
146 1970-01-01 00:01:16 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0x538317a3]
147 1970-01-01 00:01:16 PPP Information ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0x538317a3>] 00 00 00 00 00 00 00 00 00 00 00 00
148 1970-01-01 00:01:16 PPP Information ppp1 sent [LCP ConfAck id=0x5c <mru 1492> <auth chap MD5> <magic 0x618438ed>]
149 1970-01-01 00:01:16 PPP Information ppp1 rcvd [LCP ConfReq id=0x5c <mru 1492> <auth chap MD5> <magic 0x618438ed>] 00 00 00 00 00 00
150 1970-01-01 00:01:13 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
151 1970-01-01 00:01:10 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
152 1970-01-01 00:01:10 DSL Notice xDSL Enter SHOWTIME!!
153 1970-01-01 00:01:07 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
154 1970-01-01 00:01:04 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
155 1970-01-01 00:01:01 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
156 1970-01-01 00:00:58 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
157 1970-01-01 00:00:56 DSL Notice xDSL Training !!
158 1970-01-01 00:00:55 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
159 1970-01-01 00:00:52 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x538317a3>]
160 1970-01-01 00:00:52 PPP Error ppp1
161 1970-01-01 00:00:52 PPP Error ppp1 User request
162 1970-01-01 00:00:50 DSL Notice xdsl HANDSHAKE!!
163 1970-01-01 00:00:48 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
164 1970-01-01 00:00:47 DSL Notice xdsl READY!!
165 1970-01-01 00:00:45 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
166 1970-01-01 00:00:44 DSL Notice xDSL Leave SHOWTIME!!
167 1970-01-01 00:00:42 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
168 1970-01-01 00:00:39 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
169 1970-01-01 00:00:37 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
170 1970-01-01 00:00:36 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
171 1970-01-01 00:00:33 DHCPD Notice Send ACK to 192.168.1.100
172 1970-01-01 00:00:33 DHCPD Notice Recv REQUEST from 00:9C:02:AA:68:47
173 1970-01-01 00:00:33 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
174 1970-01-01 00:00:33 DHCPD Notice Send ACK to 192.168.1.150
175 1970-01-01 00:00:33 DHCPD Notice Recv REQUEST from 34:17:EB:9C:43:2B
176 1970-01-01 00:00:30 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
177 1970-01-01 00:00:30 DSL Notice xDSL Training !!
178 1970-01-01 00:00:27 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
179 1970-01-01 00:00:25 DHCPD Notice Send ACK to 192.168.1.106
180 1970-01-01 00:00:25 DHCPD Notice Recv REQUEST from B8:3E:59:6C:78:E9
181 1970-01-01 00:00:24 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
182 1970-01-01 00:00:24 DSL Notice xdsl HANDSHAKE!!
183 1970-01-01 00:00:22 DHCPD Notice Send ACK to 192.168.1.102
184 1970-01-01 00:00:22 SYSTEM Notice Enable firewall
185 1970-01-01 00:00:22 DHCPD Notice Recv REQUEST from 00:E3:B2:21:18:EB
186 1970-01-01 00:00:22 DHCPD Notice Send ACK to 192.168.1.104
187 1970-01-01 00:00:21 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x9bc5daf5>]
188 1970-01-01 00:00:21 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
189 1970-01-01 00:00:21 DSL Notice xdsl READY!!
190 1970-01-01 00:00:21 DHCPD Notice Send ACK to 192.168.1.110
191 1970-01-01 00:00:20 DHCPD Notice Recv REQUEST from B8:5E:7B:B0:33:29
192 1970-01-01 00:00:19 DHCPD Notice Send ACK to 192.168.1.101
193 1970-01-01 00:00:19 DHCPD Notice Recv REQUEST from 6C:AD:F8:6B:F7:96
194 1970-01-01 00:00:19 DHCPD Notice Send OFFER with ip 192.168.1.101
195 1970-01-01 00:00:19 DHCPD Notice Recv DISCOVER from 6C:AD:F8:6B:F7:96
30-08-2014 3:55 PM
As I said, until I reported this it had been pretty stable but then I started to get loss of internet access on all connected devices usually during the afternoons. The router, however, said that the connection had been up for 7 days or more. There were however these pp1 LCP down errors in the log at about the time of the interruptions. It would usually get itself connected again but I occasionally had to restart it.
PT
30-08-2014 4:16 PM
You might wish to redact the account details from the logs.
The router reporting being up for 7 days could well have been the xDSL session. It is not uncommon for there to be 3 uptimes reported...
1. Power on time - time since last cold start
2. xDSL uptime - time since last synch
3. PPP uptime - time since last connection set up to ISP
PPP can be dropped again with 24 hours of a resynch to change the DATA PROFILE value on PN systems, but they are usually around 3am.
Any other PPP loss without loss of synch might point to BT engineering activity or a PN gateway dropping its sessions as has happened in the last 48 hours between BT and PN issues.
Kevin
30-08-2014 4:18 PM
Is it every afternoon?
30-08-2014 4:38 PM
It did seem to be most afternoons. Not yet today (famous last words!)
I think I will watch and see regarding connections and speeds and report back anything untoward.
Thanks for your continued help on this all.
PT
24-09-2014 9:18 PM
The router had been up for over 20 days and has only just started reporting ppp errors. It doesn't seem to lose the sync though although there is an interruption in Internet connectivity.
I updated the firmware today so the router has only been up a few hours but a log since reboot shown below.
any ideas? Seems maybe my end this time as PN aren't aware of any interruptions in last 24 hours according to a post in the major interruption (? 17th Sept) thread.
1 2014-09-24 18:59:06 PPP Warning ppp1 LCP down
2 2014-09-24 18:59:06 PPP Error ppp1 LCP down
3 2014-09-24 18:58:58 PPP Error ppp1
4 2014-09-24 18:58:58 PPP Error ppp1 User request
5 2014-09-24 18:58:18 PPP Error ppp1
6 2014-09-24 18:58:18 PPP Error ppp1 User request
7 2014-09-24 18:58:07 PPP Warning ppp1 LCP down
8 2014-09-24 18:58:07 PPP Error ppp1 LCP down
9 2014-09-24 18:58:07 PPP Error ppp1 User request
10 2014-09-24 16:11:09 DHCPD Notice Recv INFORM from E0:2A:82:E2:C7:97
11 2014-09-24 15:43:35 DHCPD Notice Send ACK to 192.168.1.104
12 2014-09-24 15:43:35 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
13 2014-09-24 15:41:22 DHCPD Notice Send ACK to 192.168.1.104
14 2014-09-24 15:41:22 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
15 2014-09-24 15:08:57 DHCPD Notice Send ACK to 192.168.1.150
16 2014-09-24 15:08:57 DHCPD Notice Recv REQUEST from 34:17:EB:9C:43:2B
17 2014-09-24 14:59:05 DHCPD Notice Send ACK to 192.168.1.150
18 2014-09-24 14:59:05 DHCPD Notice Recv REQUEST from 34:17:EB:9C:43:2B
19 2014-09-24 14:58:10 DHCPD Notice Send ACK to 192.168.1.104
20 2014-09-24 14:58:10 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
21 2014-09-24 14:54:28 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
22 2014-09-24 14:53:18 DHCPD Notice Send ACK to 192.168.1.100
23 2014-09-24 14:53:18 DHCPD Notice Recv REQUEST from 00:9C:02:AA:68:47
24 2014-09-24 14:52:06 DHCPD Notice Send ACK to 192.168.1.150
25 2014-09-24 14:52:06 DHCPD Notice Recv REQUEST from 34:17:EB:9C:43:2B
26 2014-09-24 14:47:57 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
27 2014-09-24 14:46:55 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
28 2014-09-24 14:45:50 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
29 2014-09-24 14:44:32 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
30 2014-09-24 14:38:01 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
31 2014-09-24 14:36:14 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
32 2014-09-24 14:35:07 DHCPD Notice Send ACK to 192.168.1.112
33 2014-09-24 14:35:06 DHCPD Notice Recv REQUEST from 00:1B:A9:C2:2B:7D
34 2014-09-24 14:35:06 DHCPD Notice Send OFFER with ip 192.168.1.112
35 2014-09-24 14:35:06 DHCPD Notice Recv DISCOVER from 00:1B:A9:C2:2B:7D
36 2014-09-24 14:34:55 DHCPD Notice Send NAK
37 2014-09-24 14:34:55 DHCPD Notice Recv REQUEST from 00:1B:A9:C2:2B:7D
38 2014-09-24 14:34:55 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
39 2014-09-24 14:33:26 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
40 2014-09-24 14:30:37 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
41 2014-09-24 14:30:34 DHCPD Notice Send ACK to 192.168.1.102
42 2014-09-24 14:30:34 DHCPD Notice Recv REQUEST from EC:55:F9:1E:14:26
43 2014-09-24 14:29:54 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
44 2014-09-24 14:28:46 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
45 2014-09-24 14:27:35 DHCPD Notice Recv INFORM from EC:55:F9:1E:14:26
46 2014-09-24 14:26:45 DHCPD Notice Send ACK to 192.168.1.102
47 2014-09-24 14:26:45 DHCPD Notice Recv REQUEST from EC:55:F9:1E:14:26
48 2014-09-24 14:26:45 DHCPD Notice Send OFFER with ip 192.168.1.102
49 2014-09-24 14:26:45 DHCPD Notice Recv DISCOVER from EC:55:F9:1E:14:26
50 2014-09-24 13:29:52 DHCPD Notice Send ACK to 192.168.1.109
51 2014-09-24 13:29:52 DHCPD Notice Recv REQUEST from 78:61:7C:F2:30:1A
52 2014-09-24 13:29:46 DHCPD Notice Send ACK to 192.168.1.104
53 2014-09-24 13:29:46 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
54 2014-09-24 13:29:46 DHCPD Notice Send ACK to 192.168.1.110
55 2014-09-24 13:29:46 DHCPD Notice Recv REQUEST from B8:5E:7B:B0:33:29
56 2014-09-24 13:29:46 DHCPD Notice Send ACK to 192.168.1.113
57 2014-09-24 13:29:46 DHCPD Notice Recv REQUEST from E0:2A:82:E2:C7:97
58 2014-09-24 13:29:45 DHCPD Notice Send ACK to 192.168.1.110
59 2014-09-24 13:29:45 DHCPD Notice Recv REQUEST from B8:5E:7B:B0:33:29
60 2014-09-24 13:29:44 DHCPD Notice Send ACK to 192.168.1.101
61 2014-09-24 13:29:44 DHCPD Notice Recv REQUEST from 6C:AD:F8:6B:F7:96
62 2014-09-24 13:29:44 DHCPD Notice Send ACK to 192.168.1.105
63 2014-09-24 13:29:44 DHCPD Notice Recv REQUEST from 88:32:9B:73:5F:07
64 2014-09-24 13:29:44 PPP Information ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
65 2014-09-24 13:29:43 PPP Information ppp1 rcvd [CHAP Success id=0x9b ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
66 2014-09-24 13:29:43 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x26dc63a5] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
67 2014-09-24 13:29:43 PPP Information ppp1 sent [CHAP Response id=0x9b <6be9f5f5f31d2ac3b8fd15884ce448d9>, name = "xxxxx@plusdsl.ne
68 2014-09-24 13:29:43 PPP Information ppp1 rcvd [CHAP Challenge id=0x9b <93f6a0ceb81130e8d8137a12f002c1a71badf0b23b76dadca52c4d2a26fc5
69 2014-09-24 13:29:43 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0xc4ccecdc]
70 2014-09-24 13:29:43 PPP Information ppp1 rcvd [LCP ConfAck id=0x2 <mru 1480> <magic 0xc4ccecdc>] 00 00 00 00 00 00 00 00 00 00 00 00
71 2014-09-24 13:29:43 PPP Information ppp1 sent [LCP ConfAck id=0x82 <auth chap MD5> <magic 0x26dc63a5>]
72 2014-09-24 13:29:43 PPP Information ppp1 sent [LCP ConfReq id=0x2 <mru 1480> <magic 0xc4ccecdc>]
73 2014-09-24 13:29:43 PPP Warning ppp1 LCP down
74 2014-09-24 13:29:43 PPP Error ppp1 LCP down
75 2014-09-24 13:29:43 PPP Information ppp1 rcvd [LCP ConfReq id=0x82 <auth chap MD5> <magic 0x26dc63a5>] 00 00 00 00 00 00 00 00 00 00
76 2014-09-24 13:29:41 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x1da66ec4] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
77 2014-09-24 13:29:41 PPP Information ppp1 sent [CHAP Response id=0x1 <945bd4a55acfd7a1c4fd5cb19b4659ab>, name = "xxxxxx@plusdsl.net
78 2014-09-24 13:29:41 PPP Information ppp1 rcvd [CHAP Challenge id=0x1 <df41aa83dc75faf26cfc13966af1a730>, name = "bras-red12.pe"] 69
79 2014-09-24 13:29:41 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0xacf9b304]
80 2014-09-24 13:29:41 PPP Information ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0xacf9b304>] 00 00 00 00 00 00 00 00 00 00 00 00
81 2014-09-24 13:29:41 PPP Information ppp1 sent [LCP ConfAck id=0xa <mru 1492> <auth chap MD5> <magic 0x1da66ec4>]
82 2014-09-24 13:29:40 PPP Information ppp1 rcvd [LCP ConfReq id=0xa <mru 1492> <auth chap MD5> <magic 0x1da66ec4>] 00 00 00 00 00 00 0
83 2014-09-24 13:29:40 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xacf9b304>]
84 2014-09-24 13:29:39 PPP Error ppp1
85 2014-09-24 13:29:39 PPP Information ppp1 rcvd [LCP TermAck id=0x3] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
86 2014-09-24 13:29:39 PPP Information ppp1 sent [LCP TermReq id=0x3 "User request"]
87 2014-09-24 13:29:39 PPP Warning ppp1 LCP down
88 2014-09-24 13:29:39 PPP Error ppp1 LCP down
89 2014-09-24 13:29:39 PPP Error ppp1 User request
90 2014-09-24 13:28:59 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
91 1970-01-01 00:01:15 PPP Information ppp1 sent [IPCP ConfAck id=0xe7 <addr 195.166.130.140>]
92 1970-01-01 00:01:15 PPP Information ppp1 rcvd [IPCP ConfReq id=0xe7 <addr 195.166.130.140>] 00 00 00 00 00 00 00 00 00 00 00 00 00 0
93 1970-01-01 00:01:15 PPP Information ppp1 rcvd [IPCP ConfAck id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
94 1970-01-01 00:01:15 PPP Information ppp1 sent [IPCP ConfReq id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
95 1970-01-01 00:01:15 PPP Information ppp1 rcvd [IPCP ConfNak id=0x2 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
96 1970-01-01 00:01:15 PPP Information ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
97 1970-01-01 00:01:15 PPP Information ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
98 1970-01-01 00:01:15 PPP Information ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
99 1970-01-01 00:01:15 PPP Information ppp1 rcvd [CHAP Success id=0xf7 ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x511108b2] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
101 1970-01-01 00:01:14 PPP Information ppp1 sent [CHAP Response id=0xf7 <506df7461b2bd63806ce444914442639>, name = "xxxxxxx@plusdsl.ne
102 1970-01-01 00:01:14 PPP Information ppp1 rcvd [CHAP Challenge id=0xf7 <fc766a9b620dfe5b501590ddad00022ae7>, name = "JUNOS"] 00 00 00
103 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0x38bd8734]
104 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP ConfAck id=0x2 <mru 1480> <magic 0x38bd8734>] 00 00 00 00 00 00 00 00 00 00 00 00
105 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP ConfAck id=0x8f <auth chap MD5> <magic 0x511108b2>]
106 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP ConfReq id=0x2 <mru 1480> <magic 0x38bd8734>]
107 1970-01-01 00:01:14 PPP Warning ppp1 LCP down
108 1970-01-01 00:01:14 PPP Error ppp1 LCP down
109 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP ConfReq id=0x8f <auth chap MD5> <magic 0x511108b2>] 00 00 00 00 00 00 00 00 00 00
110 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x580f92fc] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
111 1970-01-01 00:01:14 PPP Information ppp1 sent [CHAP Response id=0x1 <ef652655daa12c8bdd2ee1ab1e1eff82>, name = "xxxxx@plusdsl.net
112 1970-01-01 00:01:14 PPP Information ppp1 rcvd [CHAP Challenge id=0x1 <099678ce629e6aa2f8f2eaf57d89ca98>, name = "bras-red12.pe"] d8
113 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0xf2231fbc]
114 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0xf2231fbc>] 00 00 00 00 00 00 00 00 00 00 00 00
115 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP ConfAck id=0xf7 <mru 1492> <auth chap MD5> <magic 0x580f92fc>]
116 1970-01-01 00:01:14 PPP Information ppp1 rcvd [LCP ConfReq id=0xf7 <mru 1492> <auth chap MD5> <magic 0x580f92fc>] 00 00 00 00 00 00
117 1970-01-01 00:01:14 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xf2231fbc>]
118 1970-01-01 00:01:11 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xf2231fbc>]
119 1970-01-01 00:01:10 DSL Notice xDSL Enter SHOWTIME!!
120 1970-01-01 00:01:08 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xf2231fbc>]
121 1970-01-01 00:01:05 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xf2231fbc>]
122 1970-01-01 00:01:02 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xf2231fbc>]
123 1970-01-01 00:00:56 DSL Notice xDSL Training !!
124 1970-01-01 00:00:56 PPP Error ppp1
125 1970-01-01 00:00:56 PPP Error ppp1 User request
126 1970-01-01 00:00:50 DSL Notice xdsl HANDSHAKE!!
127 1970-01-01 00:00:48 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
128 1970-01-01 00:00:47 DSL Notice xdsl READY!!
129 1970-01-01 00:00:45 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
130 1970-01-01 00:00:44 DSL Notice xDSL Leave SHOWTIME!!
131 1970-01-01 00:00:44 DHCPD Notice Send ACK to 192.168.1.105
132 1970-01-01 00:00:44 DHCPD Notice Recv REQUEST from 88:32:9B:73:5F:07
133 1970-01-01 00:00:42 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
134 1970-01-01 00:00:41 DHCPD Notice Recv INFORM from 00:9C:02:AA:68:47
135 1970-01-01 00:00:39 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
136 1970-01-01 00:00:37 DHCPD Notice Send ACK to 192.168.1.100
137 1970-01-01 00:00:37 DHCPD Notice Recv REQUEST from 00:9C:02:AA:68:47
138 1970-01-01 00:00:36 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
139 1970-01-01 00:00:33 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
140 1970-01-01 00:00:32 DHCPD Notice Send ACK to 192.168.1.150
141 1970-01-01 00:00:32 DHCPD Notice Recv REQUEST from 34:17:EB:9C:43:2B
142 1970-01-01 00:00:30 DSL Notice xDSL Training !!
143 1970-01-01 00:00:30 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
144 1970-01-01 00:00:29 DHCPD Notice Send ACK to 192.168.1.106
145 1970-01-01 00:00:28 DHCPD Notice Recv REQUEST from B8:3E:59:6C:78:E9
146 1970-01-01 00:00:27 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
147 1970-01-01 00:00:27 DHCPD Notice Recv INFORM from E0:2A:82:E2:C7:97
148 1970-01-01 00:00:24 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
149 1970-01-01 00:00:24 DSL Notice xdsl HANDSHAKE!!
150 1970-01-01 00:00:24 DHCPD Notice Send ACK to 192.168.1.104
151 1970-01-01 00:00:23 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
152 1970-01-01 00:00:22 SYSTEM Notice Enable firewall
153 1970-01-01 00:00:22 DHCPD Notice Send ACK to 192.168.1.113
154 1970-01-01 00:00:21 DHCPD Notice Recv REQUEST from E0:2A:82:E2:C7:97
155 1970-01-01 00:00:21 DHCPD Notice Send ACK to 192.168.1.101
156 1970-01-01 00:00:21 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x24e3162c>]
157 1970-01-01 00:00:21 DSL Notice xdsl READY!!
158 1970-01-01 00:00:21 DHCPD Notice Recv REQUEST from 6C:AD:F8:6B:F7:96
159 1970-01-01 00:00:21 DHCPD Notice Send ACK to 192.168.1.110
160 1970-01-01 00:00:20 DHCPD Notice Recv REQUEST from B8:5E:7B:B0:33:29
25-09-2014 8:55 AM
Estimated line speed:
14Mb (This may vary between 12Mb and 16.5Mb) - Checked on 2014-09-24 22:45:31
Current line speed:
10.1 Mb
Router status:
Upstream Downstream
Current Rate (Kbps) 1096 12888
Max Rate (Kbps) 1100 13412
SNR Margin (dB) 7 6.7
Line Attenuation (dB) 15.8 31.7
Errors (Pkts) 0 0
Why is there this speed discrepancy between what the router is reporting and the PN line speed report?
25-09-2014 10:07 AM
Have raised fault
1 2014-09-25 09:05:55 PPP Information ppp1 sent [IPCP ConfAck id=0x7b <addr 195.166.128.229>]
2 2014-09-25 09:05:55 PPP Information ppp1 rcvd [IPCP ConfReq id=0x7b <addr 195.166.128.229>] 00 00 00 00 00 00 00 00 00 00 00 00 00 0
3 2014-09-25 09:05:55 PPP Information ppp1 rcvd [IPCP ConfAck id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
4 2014-09-25 09:05:55 PPP Information ppp1 sent [IPCP ConfReq id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
5 2014-09-25 09:05:55 PPP Information ppp1 rcvd [IPCP ConfNak id=0x2 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
6 2014-09-25 09:05:55 PPP Information ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
7 2014-09-25 09:05:55 PPP Information ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8 2014-09-25 09:05:55 PPP Information ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
9 2014-09-25 09:05:55 PPP Information ppp1 rcvd [CHAP Success id=0x1d ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10 2014-09-25 09:05:55 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x64875d6f] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
11 2014-09-25 09:05:55 PPP Information ppp1 sent [CHAP Response id=0x1d <5a41a05eb7bc18f46a2b3c9a992eccb0>, name = "xxxx@plusdsl.ne
12 2014-09-25 09:05:55 PPP Information ppp1 rcvd [CHAP Challenge id=0x1d <024ee7b535c3683a2dc99750cc2695482ef2939820055dfd>, name = "JU
13 2014-09-25 09:05:55 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0xda524fa4]
14 2014-09-25 09:05:55 PPP Information ppp1 rcvd [LCP ConfAck id=0x2 <mru 1480> <magic 0xda524fa4>] 00 00 00 00 00 00 00 00 00 00 00 00
15 2014-09-25 09:05:55 PPP Information ppp1 sent [LCP ConfAck id=0xdf <auth chap MD5> <magic 0x64875d6f>]
16 2014-09-25 09:05:55 PPP Information ppp1 sent [LCP ConfReq id=0x2 <mru 1480> <magic 0xda524fa4>]
17 2014-09-25 09:05:55 PPP Warning ppp1 LCP down
18 2014-09-25 09:05:55 PPP Error ppp1 LCP down
19 2014-09-25 09:05:55 PPP Information ppp1 rcvd [LCP ConfReq id=0xdf <auth chap MD5> <magic 0x64875d6f>] 00 00 00 00 00 00 00 00 00 00
20 2014-09-25 09:05:51 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x2411de5a] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
21 2014-09-25 09:05:51 PPP Information ppp1 sent [CHAP Response id=0x1 <9c013bc46853303efe54a79017004b08>, name = "xxxx@plusdsl.net
22 2014-09-25 09:05:51 PPP Information ppp1 rcvd [CHAP Challenge id=0x1 <06c026a8725e932c4c78d757b9abd96c>, name = "bras-red12.pe"] 0e
23 2014-09-25 09:05:51 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0x7d8683ec]
24 2014-09-25 09:05:51 PPP Information ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0x7d8683ec>] 00 00 00 00 00 00 00 00 00 00 00 00
25 2014-09-25 09:05:51 PPP Information ppp1 sent [LCP ConfAck id=0x4c <mru 1492> <auth chap MD5> <magic 0x2411de5a>]
26 2014-09-25 09:05:51 PPP Information ppp1 rcvd [LCP ConfReq id=0x4c <mru 1492> <auth chap MD5> <magic 0x2411de5a>] 00 00 00 00 00 00
27 2014-09-25 09:05:51 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x7d8683ec>]
28 2014-09-25 09:05:49 DSL Notice xDSL Enter SHOWTIME!!
29 2014-09-25 09:05:48 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x7d8683ec>]
30 2014-09-25 09:05:43 PPP Error ppp1
31 2014-09-25 09:05:43 PPP Error ppp1 User request
32 2014-09-25 09:05:35 DSL Notice xDSL Training !!
33 2014-09-25 09:05:35 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
34 2014-09-25 09:05:32 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
35 2014-09-25 09:05:29 DSL Notice xdsl HANDSHAKE!!
36 2014-09-25 09:05:28 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
37 2014-09-25 09:05:26 DSL Notice xdsl READY!!
38 2014-09-25 09:05:25 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
39 2014-09-25 09:05:23 DSL Notice xDSL Leave SHOWTIME!!
40 2014-09-25 09:05:22 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
41 2014-09-25 09:05:19 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
42 2014-09-25 09:05:16 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
43 2014-09-25 09:05:13 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
44 2014-09-25 09:05:10 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
45 2014-09-25 09:05:10 DSL Notice xDSL Training !!
46 2014-09-25 09:05:07 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0xa0e01ae0>]
47 2014-09-25 09:05:07 DSL Notice xdsl HANDSHAKE!!
48 2014-09-25 09:05:02 PPP Error ppp1
49 2014-09-25 09:05:02 PPP Error ppp1 User request
50 2014-09-25 09:04:54 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
51 2014-09-25 09:04:51 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
1 2014-09-25 09:04:48 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
2 2014-09-25 09:04:45 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
3 2014-09-25 09:04:42 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
4 2014-09-25 09:04:39 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
5 2014-09-25 09:04:36 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
6 2014-09-25 09:04:33 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
7 2014-09-25 09:04:30 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
8 2014-09-25 09:04:27 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x81b1c82f>]
9 2014-09-25 09:04:27 DSL Notice xdsl READY!!
10 2014-09-25 09:04:23 DSL Notice xDSL Leave SHOWTIME!!
11 2014-09-25 09:04:23 DSL Notice xdsl HANDSHAKE!!
12 2014-09-25 09:04:23 DSL Notice xdsl READY!!
13 2014-09-25 09:04:23 DSL Notice xDSL Leave SHOWTIME!!
14 2014-09-25 09:04:23 DSL Notice xdsl HANDSHAKE!!
15 2014-09-25 09:04:18 PPP Error ppp1
16 2014-09-25 09:04:18 PPP Error ppp1 User request
17 2014-09-25 09:04:12 DSL Notice xdsl READY!!
18 2014-09-25 09:04:10 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
19 2014-09-25 09:04:09 DSL Notice xDSL Leave SHOWTIME!!
20 2014-09-25 09:04:08 DSL Notice xdsl HANDSHAKE!!
21 2014-09-25 09:04:07 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
22 2014-09-25 09:04:04 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
23 2014-09-25 09:04:01 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
24 2014-09-25 09:03:58 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
25 2014-09-25 09:03:55 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
26 2014-09-25 09:03:52 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
27 2014-09-25 09:03:49 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
28 2014-09-25 09:03:46 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
29 2014-09-25 09:03:43 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x6eb6bf15>]
30 2014-09-25 09:03:38 PPP Error ppp1
31 2014-09-25 09:03:38 PPP Error ppp1 User request
32 2014-09-25 09:03:29 PPP Information ppp1 sent [LCP TermReq id=0x4 "User request"]
33 2014-09-25 09:03:27 DSL Notice xdsl READY!!
34 2014-09-25 09:03:26 PPP Information ppp1 sent [LCP TermReq id=0x3 "User request"]
35 2014-09-25 09:03:26 PPP Warning ppp1 LCP down
36 2014-09-25 09:03:26 PPP Error ppp1 LCP down
37 2014-09-25 09:03:26 PPP Error ppp1 User request
38 2014-09-25 09:03:24 DSL Notice xDSL Leave SHOWTIME!!
39 2014-09-25 08:42:22 DHCPD Notice Send ACK to 192.168.1.104
40 2014-09-25 08:42:22 DHCPD Notice Recv REQUEST from F0:5A:09:A3:13:51
41 2014-09-25 08:36:08 PPP Information ppp1 rcvd [IPCP ConfAck id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
42 2014-09-25 08:36:08 PPP Information ppp1 sent [IPCP ConfReq id=0x3 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
43 2014-09-25 08:36:08 PPP Information ppp1 rcvd [IPCP ConfNak id=0x2 <addr 81.174.240.75> <ms-dns1 212.159.6.10> <ms-dns2 212.159.6.9>
44 2014-09-25 08:36:08 PPP Information ppp1 sent [IPCP ConfReq id=0x2 <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0.0.0>]
45 2014-09-25 08:36:08 PPP Information ppp1 rcvd [IPCP ConfRej id=0x1 <compress VJ 0f 01>] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
46 2014-09-25 08:36:08 PPP Information ppp1 sent [IPCP ConfAck id=0x7e <addr 195.166.128.195>]
47 2014-09-25 08:36:08 PPP Information ppp1 rcvd [IPCP ConfReq id=0x7e <addr 195.166.128.195>] 00 00 00 00 00 00 00 00 00 00 00 00 00 0
48 2014-09-25 08:36:08 PPP Information ppp1 sent [IPCP ConfReq id=0x1 <compress VJ 0f 01> <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns2 0.0
49 2014-09-25 08:36:08 PPP Information ppp1 rcvd [CHAP Success id=0x8b ""] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 2014-09-25 08:36:07 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x370b7fdd] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
51 2014-09-25 08:36:07 PPP Information ppp1 sent [CHAP Response id=0x8b <5188419008a12b3b923ebc15c1a0ff95>, name = "xxxx@plusdsl.ne
52 2014-09-25 08:36:07 PPP Information ppp1 rcvd [CHAP Challenge id=0x8b <7e622b80133cba0a03800a30773acff7>, name = "PTW-AG01"] 00 00 0
53 2014-09-25 08:36:07 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0x54a6f2d3]
54 2014-09-25 08:36:07 PPP Information ppp1 rcvd [LCP ConfAck id=0x2 <mru 1480> <magic 0x54a6f2d3>] 00 00 00 00 00 00 00 00 00 00 00 00
55 2014-09-25 08:36:07 PPP Information ppp1 sent [LCP ConfAck id=0xab <mru 32725> <auth chap MD5> <magic 0x370b7fdd>]
56 2014-09-25 08:36:07 PPP Information ppp1 sent [LCP ConfReq id=0x2 <mru 1480> <magic 0x54a6f2d3>]
57 2014-09-25 08:36:07 PPP Warning ppp1 LCP down
58 2014-09-25 08:36:07 PPP Error ppp1 LCP down
59 2014-09-25 08:36:07 PPP Information ppp1 rcvd [LCP ConfReq id=0xab <mru 32725> <auth chap MD5> <magic 0x370b7fdd>] 00 00 00 00 00 00
60 2014-09-25 08:36:06 PPP Information ppp1 rcvd [LCP EchoRep id=0x0 magic=0x2bd24506] 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
61 2014-09-25 08:36:06 PPP Information ppp1 sent [CHAP Response id=0x1 <b3ac358f23ee132ae3a57dcc040dfb56>, name = "xxxx@plusdsl.net
62 2014-09-25 08:36:06 PPP Information ppp1 rcvd [CHAP Challenge id=0x1 <005daebae2b98f44046501f3b9aa19b3>, name = "bras-red12.pe"] d1
63 2014-09-25 08:36:06 PPP Information ppp1 sent [LCP EchoReq id=0x0 magic=0x244c6277]
64 2014-09-25 08:36:06 PPP Information ppp1 rcvd [LCP ConfAck id=0x1 <mru 1480> <magic 0x244c6277>] 00 00 00 00 00 00 00 00 00 00 00 00
65 2014-09-25 08:36:06 PPP Information ppp1 sent [LCP ConfAck id=0xf9 <mru 1492> <auth chap MD5> <magic 0x2bd24506>]
66 2014-09-25 08:36:06 PPP Information ppp1 rcvd [LCP ConfReq id=0xf9 <mru 1492> <auth chap MD5> <magic 0x2bd24506>] 00 00 00 00 00 00
67 2014-09-25 08:36:06 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x244c6277>]
68 2014-09-25 08:36:05 DSL Notice xDSL Enter SHOWTIME!!
69 2014-09-25 08:36:03 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x244c6277>]
70 2014-09-25 08:36:00 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x244c6277>]
71 2014-09-25 08:35:53 DSL Notice xDSL Training !!
72 2014-09-25 08:35:53 PPP Error ppp1
73 2014-09-25 08:35:53 PPP Error ppp1 User request
74 2014-09-25 08:35:45 DSL Notice xdsl HANDSHAKE!!
75 2014-09-25 08:35:44 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
76 2014-09-25 08:35:42 DSL Notice xdsl READY!!
77 2014-09-25 08:35:41 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
78 2014-09-25 08:35:39 DSL Notice xDSL Leave SHOWTIME!!
79 2014-09-25 08:35:38 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
80 2014-09-25 08:35:35 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
81 2014-09-25 08:35:32 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
82 2014-09-25 08:35:29 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
83 2014-09-25 08:35:26 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
84 2014-09-25 08:35:26 DSL Notice xDSL Training !!
85 2014-09-25 08:35:23 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
86 2014-09-25 08:35:20 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
87 2014-09-25 08:35:19 DSL Notice xdsl HANDSHAKE!!
88 2014-09-25 08:35:17 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x54990ee3>]
89 2014-09-25 08:35:06 PPP Error ppp1
90 2014-09-25 08:35:06 PPP Error ppp1 User request
91 2014-09-25 08:34:58 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
92 2014-09-25 08:34:55 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
93 2014-09-25 08:34:52 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
94 2014-09-25 08:34:49 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
95 2014-09-25 08:34:46 DSL Notice xdsl READY!!
96 2014-09-25 08:34:46 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
97 2014-09-25 08:34:43 DSL Notice xDSL Leave SHOWTIME!!
98 2014-09-25 08:34:43 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
99 2014-09-25 08:34:42 DSL Notice xdsl HANDSHAKE!!
100 2014-09-25 08:34:40 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
101 2014-09-25 08:34:39 DSL Notice xdsl READY!!
102 2014-09-25 08:34:37 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
103 2014-09-25 08:34:36 DSL Notice xDSL Leave SHOWTIME!!
104 2014-09-25 08:34:35 DSL Notice xdsl HANDSHAKE!!
105 2014-09-25 08:34:34 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
106 2014-09-25 08:34:32 DSL Notice xdsl READY!!
107 2014-09-25 08:34:31 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x133f3227>]
108 2014-09-25 08:34:31 DSL Notice xDSL Leave SHOWTIME!!
109 2014-09-25 08:34:31 DSL Notice xdsl HANDSHAKE!!
110 2014-09-25 08:34:26 PPP Error ppp1
111 2014-09-25 08:34:26 PPP Error ppp1 User request
112 2014-09-25 08:34:18 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
113 2014-09-25 08:34:15 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
114 2014-09-25 08:34:12 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
115 2014-09-25 08:34:09 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
116 2014-09-25 08:34:06 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
117 2014-09-25 08:34:03 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
118 2014-09-25 08:34:00 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
119 2014-09-25 08:33:57 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
120 2014-09-25 08:33:54 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
121 2014-09-25 08:33:51 PPP Information ppp1 sent [LCP ConfReq id=0x1 <mru 1480> <magic 0x612179ad>]
122 2014-09-25 08:33:44 PPP Error ppp1
123 2014-09-25 08:33:44 PPP Error ppp1 User request
124 2014-09-25 08:33:35 PPP Information ppp1 sent [LCP TermReq id=0x4 "User request"]
125 2014-09-25 08:33:32 PPP Information ppp1 sent [LCP TermReq id=0x3 "User request"]
126 2014-09-25 08:33:32 PPP Warning ppp1 LCP down
127 2014-09-25 08:33:32 PPP Error ppp1 LCP down
128 2014-09-25 08:33:32 PPP Error ppp1 User request
129 2014-09-25 08:33:31 DSL Notice xdsl READY!!
130 2014-09-25 08:33:28 DSL Notice xDSL Leave SHOWTIME!!
131 2014-09-25 08:04:25 HTTPD Notice Clear log.
25-09-2014 12:38 PM
Sorry to hear about these issues. I've tested your service and it points at the drops being due to some form of internal issue.
This isn't the definite cause but we do need to rule this out. Please complete the checks at http://faults.plus.net and raise this to us!
25-09-2014 12:44 PM
I did that earlier but just replaced another microfilter I forgot was in place and rebooted the router. am now waiting to see.
I have also found an unused TG582n in the attic that I will try if the problem persists.
PT
25-09-2014 1:03 PM
That would be nice!
26-09-2014 3:46 PM
Download speedachieved during the test was - 10.77 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.38 Mbps
Upload Speed
0.96 Mbps
0 Mbps 0.83 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 0.96Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Why is my upload faster than max tho!
