Metronet communication problems
- Metronet communication problems
16-05-2008 10:27 PM
A couple of weeks ago my Virgin IP address changed, having been the same for several years even though it's nominally dynamic. I now find that I can communicate perfectly *from* the machine on Virgin *to* the one on Metronet, but not the other way around. Not even pings. I *can* reach the Virgin machine from other networks, e.g. the one at my place of work. The IP address of the Virgin machine is showing up correctly in DNS.
I'm assuming this is a routing problem of some kind, in one or both of the networks. Any ideas? I can provide the actual IP addresses if someone from Metronet support would care to get in touch.
Thanks.
Re: Metronet communication problems
17-05-2008 8:39 AM
Phil
17-05-2008 9:43 AM
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\chilly>tracert 84.51.xxx.xxx
Tracing route to 84-51-xxx-xxx.peterxxxx.adsl.metronet.co.uk [84.51.xxx.xxx]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms router [172.17.16.101]
2 42 ms 29 ms 28 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 28 ms 29 ms 28 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 145 ms 207 ms 201 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 31 ms 28 ms 27 ms vl22.thn-gw1.plus.net [212.159.4.3]
6 33 ms 29 ms 29 ms gi9-0-303.thn-ag3.plus.net [84.92.3.179]
7 49 ms 52 ms 52 ms 84-51-xxx-xxx.peterxxxx.adsl.metronet.co.uk [84.
51.xxx.xxx]
Trace complete.
17-05-2008 10:13 AM
Quote from: pjmarsh What router are you using on the Metronet connection? Is there anything in it's firewall that might have had the old IP address specifically set?
Phil
It's a 3COM OfficeConnect. There are no IP-specific filters set up.
17-05-2008 10:25 AM
Quote from: chillypenguin Try running a traceroute, that should show you where the connection fails;
Yes, tried that. Not very informative:
Tracing route to xxx.dyndns.org [92.237.xxx.xxx]
1 * * * Request timed out.
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
By the way, I do know that DNS is reporting the correct IP address for the target machine.
17-05-2008 12:38 PM
Are you using the Metronet firewall? In which case have you tried turning it off?
It might be stopped your traffic routing correctly. I appreciate it's working from other locations, but it definitely might be something worth trying.
17-05-2008 1:29 PM
I've raised a support ticket with the actual IP addresses. Clearly this might not be a Metronet problem, but I have to start somewhere.
cp:quote
17-05-2008 1:39 PM
How much has your Virgin IP address changed? Is it a minor one or a completely different IP address? I think by looking at the Metronet IP probably isn't helping us and we should actually be looking at the Virgin side of things instead.
17-05-2008 1:58 PM
I think you're right, by the way, about it being more likely to be a Virgin problem; but as I said I have to start somewhere.
cp:quote
17-05-2008 2:09 PM
Reckon it mioght be an idea for our support staff to see if they can traceroute to your new IP address and see what data they're able to get.
17-05-2008 4:34 PM
Quote from: Jameseh I'm not trying to detract at all from looking in to the Metronet side of things at all and I hope I didn't create that impression
You didn't create that impression.
Quote Reckon it might be an idea for our support staff to see if they can traceroute to your new IP address and see what data they're able to get.
That's what I'm hoping for. I've gone as far as I can in debugging it myself. Cheers...
17-05-2008 4:54 PM
Quote from: pwt300
Your traceroute was very informative, it did not even get out of your local network. So it looks like a local issue with the PC using the Metronet connection.
Also please can I ask you not to quote the preceding post, its unnecessary.
Chilly
17-05-2008 5:10 PM
Quote from: chillypenguin Your traceroute was very informative, it did not even get out of your local network. So it looks like a local issue with the PC using the Metronet connection.
You mean the PCs (I have several running Windows, Mac OS X and Linux) that are perfectly happily talking to every other network address except the problem one? Sorry, but I think you're wrong...
Quote Also please can I ask you not to quote the preceding post, its unnecessary.
Well that's exactly what you did, and for good reason: that's how you tell which post is being replied to, unless there's a better way.
17-05-2008 5:24 PM
Thanks for your help, everyone...
I've closed the support ticket.
