McAffee download
Nige62
McAffee download
Can someone give me a link to the page where I can download mcaffee. I had to uninstall it as it wasnt working properly and now cant find the download page.
thanks
3 REPLIES 3
Fixes: 418
Re: McAffee download
Go here and look under 'How do I get It'  https://www.plus.net/help/broadband/getting-started-with-plusnet-protect/
Personally I wouldn't touch it but I suppose that if it's free it's better than nothing.
Edit
If you look under 'how can I remove Plusnet Protect' you will see how to get it back.
Nige62
You say you wouldn't touch it.  Why, is it that bad? Thought Mcaffee would be ok or is this not a proper version ?
Fixes: 418
From what I read the latest version is OK but the earlier versions were never highly rated. I have no idea if the Plusnet offering is the latest commercial product. This might give more information. https://www.expertreviews.co.uk/software/1405437/best-antivirus-software-internet-security-keep-your...
