Master socket and extension circuits with fibre router
- Re: Master socket and extension circuits with fibr...
12-04-2013 6:49 PM
My recent installation involved a techicolor TG582n and a replacement to the existing master socket. Cone ted tothis master socket is an extension circuit upstairs. If I connected another master socket to the end of the extension line, can I move the modem upstairs without doing anything to the existing mastersocket?
Sid K
Sid K
Message 1 of 5
(1,094 Views)
4 REPLIES 4
Re: Master socket and extension circuits with fibre router
12-04-2013 6:52 PM
No as the extension upstairs is from the filtered connection on the faceplate and so won't work on broadband
Message 2 of 5
(596 Views)
12-04-2013 6:54 PM
Did the Openreach engineer fit that extension when he came to install fibre? i.e. did you ask Plusnet for a "data extension" when you placed the order?
Message 3 of 5
(596 Views)
12-04-2013 7:08 PM
No. I did try plugging in the modem at the extension both with and without a normal ASDL filter.
Sid K
Sid K
Message 4 of 5
(596 Views)
15-04-2013 11:13 AM
It could be that the engineer disconnected the socket when the fibre faceplate was fitted. It should be possible to reconnect it though would be done at your own risk - there's a few on here though that know their way around phone wiring and could help you out there with directions and suggestions.
I suspect you'd be better leaving the router in the master socket and running a length of ethernet cable up to wherever you need the internet? It'd almost certainly run faster that way.
Message 5 of 5
(596 Views)
