Massive drop in speed
- Re: Massive drop in speed
21-07-2015 11:00 PM
http://www.speedtest.net/my-result/4521841428
edit: just checked my details i dont have a estimated line speed any more and its showing 1mb as my stated speed when its always been 6-8
22-07-2015 9:32 AM
Those drops caused the profile to drop down to 1000, this has recovered to 6700 now so you should be seeing those speeds again now.
22-07-2015 9:45 AM
http://www.speedtest.net/my-result/4522809736
http://i.imgur.com/kIR2exs.png
http://i.imgur.com/CtCIj8A.png
22-07-2015 9:53 AM
A warm welcome to the forums. I would not worry about the absence of the speed estimation, nor at the moment would I be looking at speed test results. You need to focus on line synch stats and stability. Can you please follow the instructions in the speed issues thread - link below.
Is the phone line quiet? Dial 17070 option 2 using a corded phone in the master socket.
Is the router plugged into the master socket?
Are there any extension?
Kevin
22-07-2015 10:03 AM
22-07-2015 10:08 AM
