Major Disconecctions
Exsert
Right now I'm undergoing a series of MAJOR disconnections.
It Is not my router that is the problem.
I've purchased another one, and both do not work.
It all happened a week ago after I downloaded 30Gigs worth in a matter of 5 days.
Sicne then browsing is becomming impossible.... ive been a loyal member since around 2002 and dont want to have to switch ISPs
any help would be appreciated Smiley
12 REPLIES 12
Exsert
Re: Major Disconecctions
Please guys! I really need help  Sad
Fixes: 1,483
What product are you on? Is there a chance that you have gone over your product usage and are been restricted?
Exsert
Yeah I think that might be the case..
we are on Plus Net 'Pro' using 20gig
Could that be the problem?
Adie:quote
Oldjim
Resting Legend
Fixes: 63
If you haven't enabled extra usage to be added that could well be the reason
Exsert
that could be the issue, but we've added more usage..
i seriously think were being restricted Sad
Oldjim
Resting Legend
Fixes: 63
What does this say for paid for usage https://portal.plus.net/view_my_broadband_usage/index.php
jelv
Fixes: 10
Has your line developed a fault - are you still syncing at the same speeds and is your IP Profile still normal?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Exsert
Oopsies Tongue
Chris
Legend
Fixes: 169
Even if you have reached your usage allowance, that isn't going to cause the connection to actually drop. Looking at the recent connection logs on your line, something is definitely not right:
Start End Duration
18/01/2010 07:20 N/A   2:11:31 (on going)
17/01/2010 20:05 18/01/2010 00:16   4:10:12
17/01/2010 18:26 17/01/2010 19:57   1:31:24
17/01/2010 18:15 17/01/2010 18:17   0:1:22
17/01/2010 17:14 17/01/2010 18:14   1:0:3
17/01/2010 15:41 17/01/2010 17:00   1:19:22
17/01/2010 14:33 17/01/2010 15:40   1:7:14
17/01/2010 13:47 17/01/2010 14:30   0:42:56
17/01/2010 10:10 17/01/2010 12:52   2:42:8
17/01/2010 02:13 17/01/2010 09:30   7:16:48
16/01/2010 21:40 17/01/2010 02:13   4:32:31
16/01/2010 20:46 16/01/2010 21:36   0:50:30
16/01/2010 17:34 16/01/2010 20:32   2:57:18
16/01/2010 13:30 16/01/2010 17:21   3:50:6
16/01/2010 09:27 16/01/2010 12:47   3:20:28
16/01/2010 00:54 16/01/2010 01:36   0:42:2
15/01/2010 23:54 16/01/2010 00:54   1:0:3
15/01/2010 22:04 15/01/2010 23:54   1:49:30
15/01/2010 20:13 15/01/2010 22:04   1:50:37
15/01/2010 19:16 15/01/2010 20:06   0:50:34
15/01/2010 16:45 15/01/2010 17:55   1:10:9
15/01/2010 09:00 15/01/2010 15:51   6:51:30
14/01/2010 21:04 15/01/2010 00:19   3:15:13
14/01/2010 18:17 14/01/2010 19:58   1:41:0
14/01/2010 15:39 14/01/2010 16:09   0:30:31
14/01/2010 10:10 14/01/2010 10:31   0:21:8
14/01/2010 09:11 14/01/2010 10:02   0:50:34
14/01/2010 07:56 14/01/2010 09:11   1:14:54
14/01/2010 06:52 14/01/2010 07:43   0:51:41
13/01/2010 22:40 14/01/2010 00:28   1:48:5
13/01/2010 21:06 13/01/2010 22:21   1:15:9
13/01/2010 20:46 13/01/2010 21:06   0:19:24
13/01/2010 18:01 13/01/2010 19:41   1:40:17
13/01/2010 16:33 13/01/2010 17:29   0:55:32
13/01/2010 15:43 13/01/2010 16:25   0:42:39
13/01/2010 09:16 13/01/2010 15:29   6:12:52
13/01/2010 09:12 13/01/2010 09:16   0:4:2
12/01/2010 22:49 13/01/2010 00:13   1:24:4
Are you connected to the master socket? Do you have any extension leads in use? Is every phone socket filtered?
Exsert
Do you think I could be getting DDOS'd.. as it would be a co-incidence as someone said they were attacking me
jelv
Fixes: 10
DDOS attacks are not going to cause disconnections.
Exsert
Quote from: Chris
Start End Duration
Yeah it's connected to the master socket
No we do not have any extension leads currently in use
And yes every phone socket is filtered.
But the problem persists and we keep getting disconnected, any other ideas of what the problem could be? (ADSL light on modem stays solid green at all times so it's quite confusing)
