MTI value to get the best throughput?
- MTI value to get the best throughput?
03-11-2008 12:16 PM
My connection is good but is bobbing up and down between 1500 Kbps and 2000 Kbps synch speed.
What value should MTU be in this situation?
Message 1 of 8
(1,369 Views)
7 REPLIES 7
Re: MTI value to get the best throughput?
03-11-2008 12:21 PM
MTU should always be whatever is specified by the ISP, it's not speed -related.
I think PN use 1400 on BT links.
Are you thinking of RWIN, that is best increased as sync speed rises?
(defaults will generally be OK at under 2meg)
Message 2 of 8
(660 Views)
03-11-2008 12:30 PM
MTU has no affect whatsoever on sync speed!
(I have MTU on my router set to 1500)
Message 3 of 8
(660 Views)
03-11-2008 12:37 PM
Mine is currently set at 1458, just wondered if reducing this might increase stability a little.
Message 4 of 8
(660 Views)
03-11-2008 2:49 PM
If you mean stability of sync speed, then no it won't.
FWIW, after much tweaking I've settled on 1430, with an RWIN of 41700. IP Profile is 3500. YMMV of course.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 5 of 8
(660 Views)
03-11-2008 3:54 PM
I'll have a tinker when I get some time
Message 6 of 8
(660 Views)
03-11-2008 3:56 PM
I use 1430.
Message 7 of 8
(660 Views)
03-11-2008 6:31 PM
dosent really matter that much as long as your not over 1500 as then packets have to be choped up
Message 8 of 8
(660 Views)
