Low speed!! On Unlimited fibre 80/20
- Low speed!! On Unlimited fibre 80/20
Re: Low speed!! On Unlimited fibre 80/20
28-02-2013 10:54 PM
Quote from: JamieDanjoux Actually, I haven't made any changes to my wiring yet, and the wiring is not the cause of the slow speeds otherwise I wouldn't achieve 60meg in the normal times, so just be quiet!!
Can't you tell when you are having your leg pulled Jolly good job you haven't altered your Master socket too! And if that's the way you speak to, and about, forum members, you're not likely to get the help you need!
I suggest you read your other thread.
01-03-2013 8:05 PM
I checked out the thread as recommended by anotherone and reconnected on a different gateway ,,,,,,, "ptw-ag03 This is located in Telehouse West."
Much better, the full 40 Megs +
01-03-2013 8:25 PM
my ping goes up and down but I am not gaming ATM
01-03-2013 9:00 PM
01-03-2013 9:07 PM
01-03-2013 9:08 PM
Jamie
01-03-2013 9:12 PM
01-03-2013 9:14 PM
01-03-2013 9:20 PM
Then try reading this lot, here is the current page http://community.plus.net/forum/index.php/topic,111170.512.html
01-03-2013 9:21 PM
01-03-2013 9:23 PM
01-03-2013 9:28 PM
01-03-2013 9:30 PM
i am seeing terrible speeds here tonight, normally 70 meg plus, getting 5 meg, a reboot cures it in most cases,this has been ongoing for some time now.
thanks
01-03-2013 9:31 PM
I'm on ptw-ag02 now, not sure which one I was using before.
01-03-2013 9:32 PM
Quote from: Cascy Thanks Jamie
No Problem Cascy!
Also a very warm welcome to the Plusnet Community Forums!
Jamie
