Low download speed
- Low download speed
Re: Low download speed
27-06-2011 4:19 PM
30-06-2011 6:05 PM
I left the router in the test point for the last 3 days. I have done a speed test today at 18.00 as below. Can i now take the router out of the test socket(The other half is moaning at me as i have the cat5 cable running down the stairs)
30-06-2011 7:57 PM
It looks like your sync/connection speed is dropping again causing reduced speeds. Without router stats like those you attached in reply #2 I can only guess the cause of this will be target noise margin increasing again, potentially indicative of a problem.
If you want to post router stats there is no need to attach an image, it's usually easier to press the left mouse button while you drag the mouse over the page entries from left of Uptime to right of the HEC Errors value, then right-click in the highlighted area and select Copy, right click in your reply post and select Paste.
01-07-2011 7:55 PM
Uptime: 1 day, 6:02:28
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 924 / 3,968
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,808
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 349.57
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 20.0 / 34.5
SN Margin (Up/Down) [dB]: 22.0 / 22.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Signal (Local/Remote): 393,215 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 458,749 / 0
FEC Errors (Up/Down): 56 / 7,637,791
CRC Errors (Up/Down): 45 / 7,303
HEC Errors (Up/Down): 43 / 9,305
02-07-2011 12:09 AM
I think these show your target noise margin (SN Margin) will have been increased by the DLM at the exchange to 15dB (the maximum on maxDSL). At the moment your noise margin is well above that target value, suggesting the source of noise could be intermittent. Do you have a feel for how noise margin varies through the day? Recording the history of this using RouterStats can be helpful. The full version of RouterStats works out-of-the-box with the TG585, just select the ST585 v6 or v7 radio button (it works with the v8 too) and enter the admin login information. A guide to configuring RouterStats is given in this post.
The CRC and HEC Error counts shown for 1¼ days connection represent significant rates even now - whilst plugged into the test socket. This suggests the source of the problem is not related to internal wiring however I suggest you remain in the test socket over the weekend.
04-07-2011 11:25 AM
It looks like it's stayed connected solidly over the weekend, could you try disconnecting and reconnecting (via the router's interface - don't just pull any cables out or turn the router off as it'll look like a line fault if you do that) and see if the profile improves at all?
04-07-2011 7:13 PM
Uptime: 1 day, 13:05:04
Maximum Bandwidth (Up/Down) [kbps/kbps]: 924 / 4,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,000
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 78.27
Line Attenuation (Up/Down) [dB]: 20.0 / 35.0
SN Margin (Up/Down) [dB]: 22.0 / 21.0
Loss of Signal (Local/Remote): 458,748 / 0
Error Seconds (Local/Remote): 524,329 / 0
FEC Errors (Up/Down): 33 / 6,148,392
CRC Errors (Up/Down): 30 / 8,391
HEC Errors (Up/Down): 35 / NA
05-07-2011 12:24 PM
05-07-2011 4:57 PM
Not sure what you are telling me regards the figures, but initially when Jojo reset the S/N i got the results as in reply # 11, but since then it seems to be gradually slowing down again. I have just run a speed test again as below at 16:55. Can i now take the router out of the test socket as i don't think the problem is in the house wiring?
06-07-2011 9:30 AM
It should be interesting to see what difference there is on the line with the internal wiring in the equation though.
11-08-2011 7:07 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
927 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 927 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1312 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
Also having checked the router stats they are as below
Link Information
Uptime: 3 days, 13:46:18
Maximum Bandwidth (Up/Down) [kbps/kbps]: 916 / 1,440
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,312
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 530.75
Output Power (Up/Down) [dBm]: 11.5 / 17.0
Line Attenuation (Up/Down) [dB]: 21.0 / 37.0
SN Margin (Up/Down) [dB]: 22.0 / 24.0
Loss of Signal (Local/Remote): 589,819 / 0
Error Seconds (Local/Remote): 655,351 / 0
FEC Errors (Up/Down): 25 / 999,353
CRC Errors (Up/Down): 17 / 2,025
HEC Errors (Up/Down): 4 / NA
Now i am not expecting miracles but i thought i would get a bit better service than that. Is this the best you can do or can i expect something better?
11-08-2011 11:51 PM
The current sync speed is very low again, looks like line conditions were noisy when re-sync occurred. Did you initiate re-sync or was it a connection drop?
12-08-2011 2:11 PM
Did not re-sync so must have been a connection drop
12-08-2011 2:42 PM
14-08-2011 7:34 PM
Don't understand what you are telling me re the sync speed!
How do i aim for 5000kbps?
Have reconnected the router into the test socket with the following results
Link Information
Uptime: 0 days, 0:33:17
Maximum Bandwidth (Up/Down) [kbps/kbps]: 924 / 4,064
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,872
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 10.42
SN Margin (Up/Down) [dB]: 22.0 / 16.5
Loss of Signal (Local/Remote): 131,074 / 0
Error Seconds (Local/Remote): 131,289 / 0
FEC Errors (Up/Down): 24 / 1,441,265
CRC Errors (Up/Down): 26 / 9,794
HEC Errors (Up/Down): 27 / 33,530
AND
FAQ
Download Speed
883 Kbps
0 Kbps 1000 Kbps
Download speedachieved during the test was - 883 Kbps
Your DSL Connection Rate :3872 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Seems to me its worse now than it was before!
