Low Speed
- Re: Low Speed
Low Speed
31-10-2012 4:53 PM
Hey, I've been having some speed issues recently - my router had been automatically restarting itself every few hours, which made my line look unstable. However this has now been fixed and until a manual reset to do the BT Speedtest I'd had a DSL connection for 3 days 2 hours.
For my line (brand new, city centre) this seems a very slow sync.
Can you help?
DSL Connection
Link Information
Uptime: 0 days, 0:10:16
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 828 / 9,413
Data Transferred (Sent/Received) [MB/MB]: 8.46 / 115.64
Output Power (Up/Down) [dBm]: 12.2 / 21.0
Line Attenuation (Up/Down) [dB]: 11.4 / 24.0
SN Margin (Up/Down) [dB]: 8.3 / 15.1
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3 / 0
FEC Errors (Up/Down): 82 / 463
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / 19
Download speedachieved during the test was - 7.74 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.3 Mbps
Can you help?
DSL Connection
Link Information
Message 1 of 8
(1,164 Views)
7 REPLIES 7
Re: Low Speed
31-10-2012 5:20 PM
I've just submitted an SNR reset for you. Providing the line does remain stable then that should lead to some improvement in speeds.
Just out of interest what did you do to fix the issue? I'm guessing you replaced that router?
Message 2 of 8
(548 Views)
Re: Low Speed
31-10-2012 5:22 PM
Thanks Adam!
I changed the firmware - I'm using 10.2.0.B now and for some reason that's all it took to get things back to how they should be.
Fingers crossed I can keep the new higher speed.
Message 3 of 8
(548 Views)
Re: Low Speed
31-10-2012 5:27 PM
Great and no worries
It would be interesting to know when you did that as the connection seems to have been fairly stable since the weekend:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13517043477176.png" />
Message 4 of 8
(548 Views)
Re: Low Speed
31-10-2012 5:44 PM
Oh, it was before the weekend- late last week perhaps?
Message 5 of 8
(548 Views)
Re: Low Speed
02-11-2012 12:35 PM
How's your speeds at the moment? Everything is looking good from this side.
Message 6 of 8
(548 Views)
Re: Low Speed
06-11-2012 12:30 PM
Not good I'm afraid!! Back to the same problem
Message 7 of 8
(548 Views)
Re: Low Speed
06-11-2012 1:48 PM
Hi there, I've just dropped a reply in to your other thread here: http://community.plus.net/forum/index.php/topic,108996.0.html
You should find that once the dropping connection fault has been resolved your speeds should improve.
Message 8 of 8
(548 Views)
