Low SNR
Legend
Fixes: 254
Low SNR
@Gandalf I know it's early on a Sunday morning, and you may not be in the office, but it looks like DLM has gone and rest my SNR back to 3dB Cry
Any chance you could work your magic and pin it back to 6 minimum please?
9 REPLIES 9
Fixes: 1,600
Re: Low SNR
Hey John. If you PM me your landline phone number I’ll see what I can do. Smiley
Legend
Fixes: 254
Re: Low SNR
PM sent Wink
Legend
Fixes: 254
Re: Low SNR
Thanks, Anoush!Smiley
Fixes: 1,600
Re: Low SNR
No problems John. Testing the line before I made the change, I saw a lot of errored seconds (almost 900). Sad
I’ve also sent an e-mail to BTW requesting the SNR is pinned at 6db. It should be picked up tomorrow. Hopefully it stays like that from now on. Smiley
Legend
Fixes: 254
Re: Low SNR
I know about the error seconds thanks - see my previous thread.
Would changing my router correct this? Or is it something which requires Openreach?
Fixes: 1,600
Re: Low SNR
It’s possible a new router may help. I’d probably wait and see if pinning the SNR at 6db helps first.
Legend
Fixes: 254
Re: Low SNR
OK Anoush - will do.
Fixes: 1,600
Re: Low SNR
I’ve had confirmation yesterday that your circuit has been pinned to a target SNR of 6db. Hopefully it doesn’t drop down again.
Legend
Fixes: 254
Re: Low SNR
@Gandalf - Cheers, Anoush.Smiley
