Low IP Profile
- Low IP Profile
Low IP Profile
06-07-2011 4:07 PM
I have just moved home, I have kept my Phone Number as it is on the same exchange, my connection became active yesterday, but the download speeds are only a quarter to what I was previously getting, I did a BT Speed Test and got this result - "Download speed achieved during the test was - 1788 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps"
What would be the cause of such a low IP profile ?
Thank you
Joe.
Re: Low IP Profile
06-07-2011 4:43 PM
The default profile assigned to new lines is 2Mb, I'd recommend resyncing late tomorrow morning (around lunchtime is ideal) - please make sure you do so via the router's interface though rather than turning it off or unplugging it. This should cause the higher sync rate to register on the exchange equipment and push the profile update through sooner.
Re: Low IP Profile
06-07-2011 5:15 PM
Re: Low IP Profile
06-07-2011 5:45 PM
Re: Low IP Profile
06-07-2011 6:16 PM
Uptime: 0 days, 0:39:21
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Output Power (Up/Down) [dBm]: 12.0 / 7.5
Line Attenuation (Up/Down) [dB]: 4.5 / 5.0
SN Margin (Up/Down) [dB]: 29.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
jim:quote
Re: Low IP Profile
06-07-2011 6:20 PM
Re: Low IP Profile
06-07-2011 6:26 PM
Quote from: joem52 Line Attenuation (Up/Down) [dB]: 4.5 / 5.0
I didn't know BT rented out flats inside the exchange!
Re: Low IP Profile
06-07-2011 6:31 PM
Quote from: Oldjim Definitely no need to wait - however it looks as though you already have as the uptime is only 39 minutes
I did a disconnect/reconnect via router's interface, but it made no difference, IP Profile still 2000 Kbps.
Re: Low IP Profile
06-07-2011 6:31 PM
A 7150kbps profile should be applied pretty soon, the easiest way to check is to run a BT speedtester to see what profile it says is there - wait for that to increase and then go for the reboot is the safest option, but one or two power cycles a day don't harm an otherwise perfect line.
Re: Low IP Profile
08-07-2011 1:49 PM
Re: Low IP Profile
11-07-2011 10:27 AM
Looks as though it's up to 7150 now. Have you seen the difference on your side?
Jojo
