Lots of DSL drops today
kjpetrie
Fixes: 5
I've had 9 disconnections of DSL today since 11:56, which is very unusual. Usually my line stays up for days and sometimes even for months. I wonder whether there's any work going on in the Bristol area which could account for this?
24 REPLIES 24
hitchhiker43
Fixes: 4
Re: Lots of DSL drops today
I am beginning to wonder whats going on, my long rural line has had loads of trouble today and I am sure it was behaving badly yesterday too but I was to busy with other things to look closely, I know this sounds crazy but something to do with the bank holiday ? more people at home, more demand on the interne and POWER! I seem to have very long latencies and power induced REIN issues....... have you tried speedtest for latency ?
Tp-link W8960n on longgggggggg line!
kjpetrie
Fixes: 5
I suffered another disconection this morning and it reconnected with the following router stats:
DSL Connection
	Link Information
Uptime:	0 days, 0:01:12
DSL Type:	G.992.3 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:	452 / 124
Bandwidth (Up/Down) [kbps/kbps]:	444 / 200
Data Transferred (Sent/Received) [kB/kB]:	0.00 / 1.00
Output Power (Up/Down) [dBm]:	12.5 / 14.5
Line Attenuation (Up/Down) [dB]:	30.5 / 49.5
SN Margin (Up/Down) [dB]:	6.0 / 1.5
Vendor ID (Local/Remote):	TMMB / IFTN
Loss of Framing (Local/Remote):	233 / 0
Loss of Signal (Local/Remote):	1,441,773 / 0
Loss of Power (Local/Remote):	0 / 0
Loss of Link (Remote):	0
Error Seconds (Local/Remote):	5,898,151 / 0
FEC Errors (Up/Down):	0 / 2,559
CRC Errors (Up/Down):	51 / 153
HEC Errors (Up/Down):	207 / NA
Needless to say, at that speed the Internet is almost unusable. It took the best part of a minute just to log in to this page.
What is going on?
leno51
I just got on my pc and was disconnected twice also .
hitchhiker43
Fixes: 4
Your downlink snr is terrible at 1.5dB, you must have a source of bad noise on the line or something badly affecting it.
I would try the modem in the test socket to isolate your internal phone wiring.
Also try listening on your phone using the BT quiet line test on 17070 there should be no crackling
kjpetrie
Fixes: 5
I've had 3 more disconnections since my last post. It's been down more than it's been up. Next time it drops I'll plug into the test socket - I don't want to cause any drops by unplugging anything because that'll just make things worse in the short term.
 Current stats:
DSL Connection
	Link Information
Uptime:	0 days, 0:16:03
Maximum Bandwidth (Up/Down) [kbps/kbps]:	1,040 / 3,976
Bandwidth (Up/Down) [kbps/kbps]:	444 / 3,768
Data Transferred (Sent/Received) [kB/MB]:	798.00 / 2.08
Output Power (Up/Down) [dBm]:	12.5 / 18.0
Line Attenuation (Up/Down) [dB]:	30.5 / 49.0
SN Margin (Up/Down) [dB]:	23.5 / 3.0
Loss of Framing (Local/Remote):	321 / 0
Loss of Signal (Local/Remote):	1,572,848 / 0
Error Seconds (Local/Remote):	6,356,949 / 0
FEC Errors (Up/Down):	0 / 749,507
CRC Errors (Up/Down):	32 / 2,623
HEC Errors (Up/Down):	7 / 25,859
So the increased power has helped, if it's stable...
PS - no noise on quiet line test - but the ratio has improved enormously from what it was earlier this morning, and I haven't changed anything this end.
(PPS there still remains the mystery of how I'm clocking up error seconds at around 100/sec.)
Fixes: 1,600
Hi there @kjpetrie
I am sorry to hear you are experiencing drop outs. Looking at your connection logs, things don't seem too good.
I'm testing your broadband and this isn't identifying why the drop outs are occurring.
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 30.5 49.0
SNR Margin: 23.0 5.8
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 5247 8639
Speed: 444 3768
It's possible we may need to send an engineer to investigate.
I would advise to plug your router into the test socket, and let us know how you get on?
kjpetrie
Fixes: 5
Thanks, I appreciate it's safer to use the test socket and disconnect all internal wiring and equipment to eliminate the possibility I've got a dodgy phone or similar upsetting proper function. However, I'm sure you can also see that the pattern is that it can remain up for days and then become unstable for a few hours, only to settle down for a few more days, which means I'd potentially have to stay without phones and on the test socket for up to a few weeks to come to a conclusion if that were the case.
I'm in the process of selling a house and the agent needs to be able to contact me, so that's not very practical at the moment. Also, if your tests showed nothing it's quite possible we have an intermittent problem that might not be there when the engineer looks. It seems so far to happen during the 12 hours starting early morning (4 am on) which makes me wonder whether it's related to some human activity. Evening and small hours seems fine.
Fixes: 1,600
You should be able to plug a phone handset into the test socket with your router, using a microfilter?
kjpetrie
Fixes: 5
But what would we then be eliminating, other than the faceplate of the socket box? Is that a component likely to be responsible?
The only internal wiring I have is the microfilter, a handset, my router, and a cable to a cordless base station (all plugged into the microfilter). Those are not conveniences; they are necessary to enable me to hear incoming calls wherever I am in the house, so if I disconnect any of them I could miss a vital call at a critical stage in the next few days. We need to eliminate these internal devices, but I can't afford to disconnect them just now.
There is nothing wired into the box directly, so nothing gets disconnected if I take the faceplate off the box and use the master socket instead.
DSL has been up for 22 hrs 25 min now, at around half usual download speed.
MatthewWheeler
Fixes: 479
There is a chance the faceplate could be faulty which is why we advise you to connect to the test socket.
In addition this is the same socket a engineer would test from.
 Matthew Wheeler
kjpetrie
Fixes: 5
OK, I had a DSL drop around lunchtime, so I took the opportunity to plug into the test socket. I'll leave things that way, but I'm not convinced we'll learn much. The pattern shown in the graphic representation looked like an intermittent rather than a continuous problem, possibly related to some temporary disruption, either at the exchange or by EM interference somewhere along the route of the line. It seemed to be mostly during an extended working day (beginning around 4 am and including Sunday) and was concentrated on Wednesdays and weekends. If it recurs we have eliminated the faceplate. If not, I'm not sure we learn anything, because the problem might not recur anyway if it was linked to some human activity which has now ceased. I did check the quiet line test while DSL was off, but apart from a faint brief whine as sync was re-established the line remained noise free.
These are the current stats, as reported by the router:
Link Information
Uptime:	0 days, 9:20:07
Maximum Bandwidth (Up/Down) [kbps/kbps]:	1,072 / 3,588
Bandwidth (Up/Down) [kbps/kbps]:	444 / 2,328
Data Transferred (Sent/Received) [MB/MB]:	5.00 / 38.94
Output Power (Up/Down) [dBm]:	12.5 / 18.5
Line Attenuation (Up/Down) [dB]:	30.0 / 49.5
SN Margin (Up/Down) [dB]:	24.0 / 8.0
Loss of Signal (Local/Remote):	1,638,377 / 0
Error Seconds (Local/Remote):	6,553,506 / 0
FEC Errors (Up/Down):	0 / 85,678
CRC Errors (Up/Down):	39 / 210
HEC Errors (Up/Down):	14 / 2,291
leno51
Mine has rebooted also and my ping time has increased a little ..
kjpetrie
Fixes: 5
Latest figures show profile dropping slowly but speed increasing.
Link Information
Uptime:	0 days, 12:56:14
Maximum Bandwidth (Up/Down) [kbps/kbps]:	1,020 / 3,276
Bandwidth (Up/Down) [kbps/kbps]:	444 / 2,648
Data Transferred (Sent/Received) [MB/MB]:	13.34 / 16.59
SN Margin (Up/Down) [dB]:	22.5 / 5.0
Error Seconds (Local/Remote):	1 / 0
FEC Errors (Up/Down):	16,960 / 2,446,080
CRC Errors (Up/Down):	1,315 / 12,283
HEC Errors (Up/Down):	NA / 108,502
ejs
Aspiring Hero
Fixes: 25
I'm guessing this is a fairly old modem/router, the 585v8? I'd prefer to try a new modem/router before calling out Openreach.
