Loss of link during the evening
- Loss of link during the evening
19-09-2007 10:16 AM
Sep 17 22:32:03 critical kernel: ADSL link down
Sep 17 22:32:04 critical pppd[331]: Clear IP addresses. Connection DOWN.
Sep 17 22:32:04 critical pppd[331]: Clear IP addresses. PPP connection DOWN.
Sep 17 22:32:10 critical kernel: ADSL G.994 training
Sep 17 22:32:15 critical kernel: ADSL G.992 started
Sep 17 22:32:20 critical kernel: ADSL G.992 channel analysis
Sep 17 22:32:21 critical kernel: ADSL link up, interleaved, us=448, ds=4800
Sep 17 22:32:24 critical pppd[331]: PPP LCP UP.
The last line is repeated about every 8 seconds until such time as I reboot it. When it is rebooted I get exactly the same except the last line is not repeated but followed by:
Jan 1 00:00:30 critical pppd[331]: Received valid IP address from server. Connection UP.
This would appear to indicate that when the link is lost the router is calling but not getting a valid IP address back and will therefore not reconnect. The router is set to accept server assigned address.
I have had a ticket (22636721) running sometime regarding loss of link and I am told that the fall in sync rate is not enough to warrant a BT call out.
When I raised the specific question as to why the router is not automatically reconnecting PN ignored it.
Anyone any ideas?
Mike
Re: Loss of link during the evening
19-09-2007 10:26 AM
Does your drop in speed coincide with street lighting? This is a potnetial cause of the problems that you are seeing, with the street lighting causing interference with the broadband signal down your phone line.
Regarding the router not reconnecting asutomatically, this will be down to your router failing to reattain the connection, not anything that BT or PlusNet are doing.
19-09-2007 10:27 AM
19-09-2007 10:51 AM
The reconnection issue was only addressed when I asked for an answer to my question which had been ignored. I have tried 2 routers and get the same problem. I am hoping to borrow another one and try that but find it hard to believe that I have 2 faulty routers.
Secondly the streetlight question has also been addressed. I was originally suspicious of this but the fall in SNR starts before the lights come on.
I have had this irritating problem for months now and because the drop in sync rate is so say within acceptable margins a BT callout comes with the threat of a hefty bill. As a pensioner I am none too happy with that.
Mike
19-09-2007 11:43 AM
Thanks for taking the time to talk to me earlier.
As discussed, I've now raised your fault to BT and will update you as soon as I have heard back from them.
19-09-2007 1:02 PM
My office connection has a NetGear DG834 and I have seen that do a similar thing , it also will not reconnect until rebooted.
Thats on Demon so I dont think it's a Plusnet problem.
I guess some routers are just not good at reconnecting...
I hesitate to suggest checking if any firmware updates are available for the router as that could just open another can of worms!!
19-09-2007 1:42 PM
It would seem that this characteristic is a feature of more than one model of the Belkin router range, perhaps the two mentioned have the same chip-set.
25-09-2007 8:14 PM
Since my post I have had a visit from BT. One faulty socket which was BT installed some years ago otherwise all was well with setup. I have tried 2 different Belkin modems and both still fail to reconnect unless rebooted. Today I am trying a DLink borrowed from my neighbour and this appears to reconnect without problems.
Looks as though I will have to get the plastic out and buy a new modem or maybe take the Belkin back saying it is not fit for purpose! Question is "What modem to get?"
26-09-2007 1:59 PM
However we still have not solved the underlying problem of SNR drop. Line is rock solid through the day and this is what happened yesterday:
Logged on in morning before 9am. Sync rate 7008
At 1910 modem resynced at 6336
At 1943 another drop to 5856
and at 2111 dropped to 5472.
It held steady until shut down at about 2330.
This morning sync rate is 7104
The drop yesterday was about 22%. Question is "Where is the noise coming from?"
Anyone with a crystal ball?!!
