Looks like we can now get a faster speed if I change my product, help please.
- Looks like we can now get a faster speed if I chan...
30-09-2011 9:52 PM
Been a while since I posted on here, but I usually get some great help from the staff so I thought I would fire a new question on here ( I know it's the weekend now so may not get a reply til next week).
BT openreach have been doing a lot of work in my area in preparation for FTTC due at the end of this year so I have been keeping my eyes on things.
Today I went to BT's website and typed in my phone number as usual to see if any updates on FTTC had come up.
It still stated December for FTTC but it now stated I could should be able to get 17mb down my current line, I am guessing adsl2+?
At present I get 6.6meg and do have the adsl2+ router.
I logged our account on plusnet and it states if I change my product to "extra" or "Value" the estimated speed will be 17mb however the change won't take place until our next billing date which is the 19th October
Is there any way this can be speeded up?
We would want the extra product.
Hope that all makes sense and sorry for the long post.
Regards
Paul.
EDIT: ALL SORTED NOW, SEE LAST POST.
Re: Looks like we can now get a faster speed if I change my product, help please.
30-09-2011 10:39 PM
what package are you currently on as that might make even more changes - lower price, more G, different feature
30-09-2011 11:15 PM
Cheers
Paul.
30-09-2011 11:20 PM
If your sync is only 6.6Mb/s then either BT are telling porkies or something is adrift with your line.
Can you post the stats from your router and also put your post code (not telephone number) into http://www.kitz.co.uk/adsl/adslchecker.php
01-10-2011 12:10 AM
Well this is something that has changed within the last 24hrs, yesterday both BT and plusnet said I could get upto 8meg and the estimate was 7meg. Both sites today now show 17meg
What info do you want from the 2nd link?
It says -
Fixed ADSL: 2048 kbps (2 Mb)
DSL Max: 7500 kbps (7.5 Mb)
21CN WBC : 17000 kbps (17 Mb)
I thought perhaps if the new speeds had only been available for the last day then perhaps plusnet need to do something their end?
01-10-2011 2:00 AM
If you want to change to Extra your data allowance would reduce to 60GB, but the cost would be £2 or £4.50 per month cheaper (depending on which market your exchange is in). That change would have to take place at next billing date.
David
02-10-2011 9:02 PM
To be honest I am at this moment unsure if it is Adsl2+, I am hoping someone from plusnet can look into it tomorrow for me and see if we can actually get the faster speeds.
It would be much easier if we could stay on the same product, we pay extra for the low latency add on, can't remember what its called now.
If I get nowhere on the forum tomorrow then I will give them a bell towards the end of the day to see what's what.
Cheers
Paul.
02-10-2011 10:01 PM
http://www.kitz.co.uk/adsl/frogstats.php
03-10-2011 10:17 AM
I have tried absolutely everything to get into my router but with no luck.
I reset the router by holding in the button on the back til all the lights came on.
I then assumed that to enter it I would either just put "Administrator" and leave password blank or put "Administrator" and put serial number of the router in for the password.
So I can't post my router stats I'm afraid.
03-10-2011 10:24 AM
03-10-2011 10:29 AM
03-10-2011 10:31 AM
Admininistrator for the early ones
the number on the unit for recent (Casesensative
the V 8 is the number/word on the unit
03-10-2011 10:37 AM
DSL Type: G.992.5 annex A
992.3 is ADSL1
03-10-2011 10:42 AM
I am now into the router.
It says G.992.1 annex A
03-10-2011 12:41 PM
Thanks again for peoples help on here.
Will let you know how the speeds are after.
Paul.
