Login details for router
- Login details for router
09-03-2015 9:58 AM
Hello again,
Because of my previous problems, I have installed the router supplied by Plusnet, it's the Technicolor TG582n, problem is I cannot find the default username\password combo. Would be very grateful if some kind soul would point me in the right direction. Thanks in advance.
Message 1 of 4
(1,130 Views)
3 REPLIES 3
Re: Login details for router
09-03-2015 10:01 AM
Message 2 of 4
(974 Views)
09-03-2015 10:09 AM
Thank you for info Oldjim appreciated, and in.
Message 3 of 4
(974 Views)
09-03-2015 10:36 AM
Assuming the problem you refer to is the one being discussed in your thread about DNS lookups, changing the router won't make any difference.
The TG582n is not as easy to configure as the Billion you were using, especially if the ultimate fix is to change the DNS server that the router uses for look ups.
Message 4 of 4
(974 Views)
