Local Access Only - No Internet
- Re: Local Access Only - No Internet
- « Previous
- Next »
17-01-2014 3:29 PM
http://support.microsoft.com/kb/929852
Message 46 of 51
(440 Views)
17-01-2014 3:38 PM
Quote from: MisterW http://support.microsoft.com/kb/929852
Heck, that seems a bit drastic for me to do!
Message 47 of 51
(440 Views)
17-01-2014 3:59 PM
You can always use the Fix it's to automate the process for you Plus they supply the 1 to reverse the process
screenshot software
screenshot software
Message 48 of 51
(440 Views)
17-01-2014 4:26 PM
Follow the instructions in http://www.plus.net/support/software/dns/changing_dns_vista.shtml as far as step 4.
When you have the screen display shown in step 5 select Internet Protocol Version 6 (TCP IPv6) and click Uninstall. Then click OK.
Message 49 of 51
(440 Views)
17-01-2014 4:35 PM
I'll have a look at that on Monday. I've had enough for now!
Message 50 of 51
(440 Views)
20-01-2014 1:01 PM
This morning, switched the laptop on with wireless enabled - nothing - still local access only and no settings retained.
Plugged the ethernet cable in and I had an instant internet connection and the settings suddenly appeared for both wired and wireless but if I take the cable off I'll lose them all again. Weird!
Will have a look at disabling IPv6 later.
Message 51 of 51
(440 Views)
- « Previous
- Next »
