Local Access Only - No Internet
Lynnpin
I finally took the plunge for Business Phone and Broadband and since activation on Monday I've been tearing my hair out trying to get online with my laptop.  It won't work with wireless or wired and I cannot even access the router page.
Last night I took the laptop home and it connected immediately so I know the laptop isn't faulty.  But now I'm stuck!
I read these network connection details last night on my home broadband (which is also with Plusnet):
IPv4 Default Gateway 192.168.1.254
IPv4 DHCP Server 192.168.1.254
IPv4 DNS Server 192.168.1.254
But on my business broadband these are blank, so could that have anything to do with it?
There are a few similar problems in the Plusnet forums and some suggest updating drivers, which I have done to no effect (Broadcom).
I've researched this and it seems to be a fairly common occurrence with Vista laptops/computers but nothing I've done can resolve it.
As a last resort today I rang Plusnet customer service but was effectively told by James that it was a faulty laptop and not Plusnet's problem.  Charming!
50 REPLIES 50
orbrey
Re: Local Access Only - No Internet
That does sound like the laptop is unable to connect to the router. If other computers are able to then the advice you were given is the most likely reason.
Is it possible to try and connect the laptop using a network cable, and test it that way? If it works in that situation then there's a wireless issue somewhere, and if other PCs can connect wirelessly then I'm afraid that points straight to the laptop's wireless.
Lynnpin
Thanks for your quick response Matt.
As I said, I have tried to connect with the network cable but that doesn't work either.
This fix suggests that certain routers or DHCP servers are incompatible with Windows Vista and is about disabling the Broadcast Flag so I don't know if this has something to do with it. http://support.microsoft.com/kb/928233/en-us
orbrey
Right, very weird. Do other computers connect to the business router? If not, what are the lights on the router showing when it's powered up and plugged into the phone line?
Lynnpin
Yes the other laptop which runs XP is working fine with the business router.  All the lights are on - Internet, Broadband and WiFi and Ethernet lights up when I have a cable plugged in.
jelv
Fixes: 10
Could you open a command prompt and run
ipconfig /all
please. That might tell us something.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Lynnpin
Unfortunately the laptop has been switched off now but I'll do that first thing tomorrow.  Actually,  I did try that and I think it was something to do with the number 169 showing up somewhere if the router didn't know where to go to?  It may have been your post in another thread.  And it was actually showing as 169xxxxxxxxxx but I'll confirm again tomorrow.
Gel
Aspiring Champion
Fixes: 29
I've 2 laptops with Vista and both work fine with + Net Servers; one is on Vista Business, one is Vista Premium or someat!
Is your router set to get DNS automatically or is it pointing at one of + Nets DNS's such as 212 159 13 49+ 50 ?? (Secondary)
orbrey
Quote from: Lynnpin
Ah. That is an IP that Windows assigns itself when there's some kind of networking error, so I'm afraid it's very much looking like a laptop issue. You might be able to resolve it from a command prompt, with some more use of the ipconfig command jelv mentions:
first, ipconfig /release
then, ipconfig /renew
That should renew the network configuration and makes the laptop request another IP from the router. If that doesn't work you'll need to check your network settings, but more on that tomorrow Smiley
Lynnpin
Thanks all - will do it first thing tomorrow and let you know.
I still don't know why it works with my home broadband though unless it's just a Vista thing!  Huh
Lynnpin
As promised, the log is appended below.
One thing I forgot to mention was initially I was getting a message "press the configuration button on your access point" which I was clueless about but there was an option underneath  to enter the password manually which I did but still to no effect.  That seems to have disappeared now.
C:\Users\john>ipconfig /all
Windows IP Configuration
  Host Name . . . . . . . . . . . . : john-PC
  Primary Dns Suffix  . . . . . . . :
  Node Type . . . . . . . . . . . . : Hybrid
  IP Routing Enabled. . . . . . . . : No
  WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
  Media State . . . . . . . . . . . : Media disconnected
  Connection-specific DNS Suffix  . :
  Description . . . . . . . . . . . : Bluetooth PAN Network Adapter
  Physical Address. . . . . . . . . : 00-15-83-15-A2-04
  DHCP Enabled. . . . . . . . . . . : Yes
  Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
  Description . . . . . . . . . . . : Broadcom 802.11g Network Adapter
  Physical Address. . . . . . . . . : 00-19-7D-89-3D-20
  Link-local IPv6 Address . . . . . : fe80::243f:7f89:797b:9245%9(Preferred)
  Autoconfiguration IPv4 Address. . : 169.254.146.69(Preferred)
  Subnet Mask . . . . . . . . . . . : 255.255.0.0
  Default Gateway . . . . . . . . . :
  DHCPv6 IAID . . . . . . . . . . . : 151001469
  DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0D-DE-FC-E5-00-16-D4-C8-B4-75
  DNS Servers . . . . . . . . . . . : fe80::9e97:26ff:fe4f:9978%9
  NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
  Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controlle
r
  Physical Address. . . . . . . . . : 00-16-D4-C8-B4-75
Tunnel adapter Local Area Connection* 14:
  Description . . . . . . . . . . . : isatap.{439D2219-93AD-495A-AD91-5D24CD231
645}
  Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
  DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 16:
  Description . . . . . . . . . . . : isatap.{6BB79F38-46AF-4545-BA54-A15AC775A
422}
Tunnel adapter Local Area Connection* 18:
  Description . . . . . . . . . . . : isatap.{C6F44361-D15E-410C-B5EF-7CEBFE3C5
D4D}
Tunnel adapter Local Area Connection* 19:
D4D}
Tunnel adapter Local Area Connection* 21:
  Description . . . . . . . . . . . : isatap.{DA009FC0-DA5B-4896-9E3D-B97D01219
992}
Tunnel adapter Local Area Connection* 22:
  Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
  Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 23:
D4D}
jelv
Fixes: 10
Can you try that again using a wired connection please.
Lynnpin
Here's the wired version:
r
  Link-local IPv6 Address . . . . . : fe80::d8cb:f7c0:99b:f74%8(Preferred)
  Autoconfiguration IPv4 Address. . : 169.254.15.116(Preferred)
  DHCPv6 IAID . . . . . . . . . . . : 201332436
  DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                      fec0:0:0:ffff::2%1
                                      fec0:0:0:ffff::3%1
645}
422}
D4D}
D4D}
992}
D4D}
dick:quote
jelv
Fixes: 10
That is odd - it's still not picking up an IP address.
Are other PCs picking up IP addresses from the router DHCP?
Lynnpin
This is the log from my XP computer currently connected via wireless:
C:\Documents and Settings\john>ipconfig /all
        Host Name . . . . . . . . . . . . : your-e659457a65
        DNS Suffix Search List. . . . . . : lan
Ethernet adapter Wireless Network Connection:
        Connection-specific DNS Suffix  . : lan
        Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Networ
k Connection
        Physical Address. . . . . . . . . : 00-18-DE-B5-6F-D5
        Dhcp Enabled. . . . . . . . . . . : Yes
        IP Address. . . . . . . . . . . . : 192.168.1.65
        Subnet Mask . . . . . . . . . . . : 255.255.255.0
        Default Gateway . . . . . . . . . : 192.168.1.254
        DHCP Server . . . . . . . . . . . : 192.168.1.254
        DNS Servers . . . . . . . . . . . : 192.168.1.254
        Lease Obtained. . . . . . . . . . : 16 January 2014 09:12:01
        Lease Expires . . . . . . . . . . : 17 January 2014 09:12:01
        Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connecti
on
        Physical Address. . . . . . . . . : 00-A0-D1-5F-DD-0B
Ethernet adapter Bluetooth Network:
        Description . . . . . . . . . . . : Bluetooth LAN Access Server Driver
        Physical Address. . . . . . . . . : 00-19-86-00-32-CE
