Line trained but stuck at 12dB SNRM, what do I do now?
- Line trained but stuck at 12dB SNRM, what do I do ...
Re: Line trained but stuck at 12dB SNRM, what do I do now?
05-02-2013 3:27 PM
05-02-2013 3:42 PM
If there had not been dropouts would it have asked different questions?
05-02-2013 10:23 PM
When you did the modem/router and filter swaps did you use the disconnect method and stay off for at least 10 minutes?
Edit: What MW frequencies did you try? Try 531kHz, 549kHz, 585kHz, & 594kHz.
06-02-2013 9:45 AM
I am just off to see if I can pick it up outside. The neighbours may think me a bit odd walking up the road waving a radio about but I suspect they think I am a bit odd anyway.
06-02-2013 10:19 AM
06-02-2013 1:34 PM
Thanks for that, should really help - regarding the fault though it looks like it's been picked up as a phone fault so I'd hope the automated tests have picked something up there. We're happy to progress it how you wish though, just let us know
06-02-2013 3:59 PM
I am not sure what you mean by progressing as I wish, is there a choice?
I have not had a reply to the fault report yet, should I have? Or is it just working its way through the system?
Thanks for the help
Colin
06-02-2013 5:06 PM
06-02-2013 5:10 PM
06-02-2013 8:18 PM
In any event, you can always pursue it as a broadband fault later if nothing gets resolved as a phone fault!
Glad, you've managed to pick up something on the radio, let's hope you can pin it down.
06-02-2013 8:54 PM
07-02-2013 12:17 PM
07-02-2013 1:14 PM
07-02-2013 3:21 PM
11-02-2013 5:51 PM
