Line speed problem - banding?
- Line speed problem - banding?
- « Previous
- 1
- 2
- Next »
Re: Line speed problem - banding?
07-03-2011 1:29 PM
ok jojo thanx any chance i can get my line retrained aswell as the line now seems sold so i can get my ip profile raised again
Message 16 of 24
(588 Views)
07-03-2011 5:33 PM
Hi Gerry,
I've requested that but their system is taking a while for it to go through. I'll check it in the morning for you.
Jojo
Jojo
Message 17 of 24
(588 Views)
08-03-2011 10:48 AM
ok thanx jojo
my dsl just disconnected a few moments ago so im assuming that was it being done well im hoping it was otherwise the last 5 days of solid connection will have been for nothing here are my latest line stats
Link Information
Uptime:0 days, 0:29:36
DSL Type:G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:25,499 / 21,016
Bandwidth (Up/Down) [kbps/kbps]:448 / 6,656
Data Transferred (Sent/Received) [MB/MB]:1.01 / 2.42
Output Power (Up/Down) [dBm]:12.5 / 18.0
Line Attenuation (Up/Down) [dB]:5.0 / 9.5
SN Margin (Up/Down) [dB]:26.5 / 22.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):1 / 0
CRC Errors (Up/Down):304 / 1
HEC Errors (Up/Down):8 / 0
Link Information
Message 18 of 24
(588 Views)
08-03-2011 11:24 AM
Hi Gerry,
They've had trouble changing your profile. I will get back onto them again shortly.
Jojo
Jojo
Message 19 of 24
(588 Views)
08-03-2011 6:53 PM
ok thank you jojo
Message 20 of 24
(588 Views)
09-03-2011 9:19 AM
Hi Gerry,
Hoping for some news this morning, will keep you informed.
Jojo
Jojo
Message 21 of 24
(588 Views)
09-03-2011 9:53 AM
HI Gerry,
Ok that's all sorted now. The banding has been lifted, your sync is 17112 and the bRAS will change to 15000 in under 12 hours if it stays stable.
Jojo
Jojo
Message 22 of 24
(588 Views)
09-03-2011 11:26 AM
hi jojo
many thanks for your assistance the moem is going to stay in the test socket anyway so i dont anticipate any further problems with stability
Gerry
Gerry
Message 23 of 24
(588 Views)
09-03-2011 11:48 AM
You're welcome. Gerry. At least if there were to be any issues in the test socket it would be easier to investigate, although I think it will probably be fine now
Message 24 of 24
(588 Views)
- « Previous
- 1
- 2
- Next »
