Line speed V's actual speed
OK, so there was a fault on my line which BT Openreach fixed on Friday. (apparently there was a second connection in the junction box going somewhere else)
I originally raised the query because the actual I get is about half the estimated speed. Now the fault has been fixed, apparently I should be able to get a much better speed.
According to BT Wholesale speed checker though my broadband speed is still below what it should be.
Should I raise another ticket for this, or is this the best I can expect?
7 REPLIES 7
Fixes: 62
Re: Line speed V's actual speed
I have, yes. It says pretty much the same thing.
Phone exchange:
    STIRLING
Estimated line speed:
    78Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-02-02 14:48:57
Current line speed:
    40 Mb
This has not been updated since I signed up. The speed check was done on Sky's equipment.
The reply I got regarding the line fault was that my broadband should now also be running at full speed. BT Wholesale seem to think the acceptable spped range for my connection should be between 60mbs and 77.43mbs. I agreed to sign up on this basis, and wondered whether these speeds are likely.
Fixes: 62
That is an easy fix - should be picked up here
Jolly good. I'm still quite chuffed with PlusNet over-all compared with Sky. Customer service is amazing by comparison, and my broadband has been completely stable. A line fault that Sky refused point blank to acknowledge has been addressed. (The BT bloke was a bit hacked off that it wasn't picked up on a previous visit.)
Fixes: 117
I've just corrected the speed profile for you so you should see some improvement straight away.
 Adam Walker
Fixes: 62
You may need to disconnect/reconnect the router (not the modem)
Super guys. I'll see if anyone is home at the moment and ask them to run a test. If not, I'll do it this evening.
Thanks again. This company should be a benchmark for all others.
