Line reset needed?
- Re: Line reset needed?
Line reset needed?
05-08-2013 12:53 PM
Hi chaps,
Was getting major disconnects a few weeks ago. Was told my router was dying. Have fitted new router and filters and apart from 2 power outtages my line seems stable.
But I've lost some speed. Was told I may need a line reset after its settled. Is that something someone can look at without breaking my broadband? 🙂
Was getting nearly 6.3mbps. Now on 5.4mbps.
Message 1 of 7
(1,043 Views)
6 REPLIES 6
05-08-2013 3:13 PM
Hi, just requested that for you - it should take effect later on this afternoon/evening. Hope it improves things for you.
Message 2 of 7
(579 Views)
05-08-2013 3:15 PM
Thanks.
Will let you know later.
Message 3 of 7
(579 Views)
06-08-2013 12:04 AM
Not sure if anythings happened?
Router still shows it was connected for 7 days
Message 4 of 7
(579 Views)
06-08-2013 10:17 AM
Hmm, odd. I've resubmitted it for you, hopefully it'll work this time - sorry about that.
Message 5 of 7
(579 Views)
07-08-2013 4:36 PM
Er....still showing a 9 day old connection now.
What gives?
What gives?
Message 6 of 7
(579 Views)
07-08-2013 5:17 PM
Wish I knew 😕 Given that I've tried twice I'd say it's probably worth raising a fault through to our team, they'll look into it and get it sorted for you. You can do that at http://faults.plus.net, hope it's fixed quickly.
Message 7 of 7
(579 Views)
