Line Speed Throttled
- Line Speed Throttled
17-02-2009 11:14 AM
My problem is that BT and F9 have a line profile for me of 2500 kbps but I can only download at a maximun of 1700kbps, i.e. the line is profiled somewhere at 1750 kpbs either on F9 or BT's system.
Here are the facts:-
from F9
High-speed Broadband
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
2500
From BT:-
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2848 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2500 kbps
Actual IP throughput achieved during the test was - 1500 kbps
From "My Broadband Speed"
Today 10:47 1666 kbps (208kB/s) 378 kbps (47.3kB/s)
and from my router:-
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT Annex A
Downstream Rate: 2848 kbps
Upstream Rate: 448 kbps
Channel: Fast
Current Noise Margin: 12.0 dB (Downstream) 21.0 dB (Upstream)
Current Attenuation: 56.4 dB (Downstream) 31.5 dB (Upstream)
Current Output Power: 18.2 dBm (Downstream) 11.9 dBm (Upstream)
I think you can agree from the above data that I should be recieving a line rate of close to 2500 kbps, but somewhere along the way I am being throttled at 1750 kbps whether this is at plus.net or BT, I'm not sure but I hope you will be able to advise on the issue or what to do to get the line un-throttled.
Dave
Re: Line Speed Throttled
17-02-2009 12:46 PM
Because you're using a contended service, you will not always get the "profiled" speed because of contention and line overheads.
The speeds you're getting are actually perfectly reasonable given your line conditions.
17-02-2009 1:03 PM
17-02-2009 1:05 PM
Have you tried rebooting your router recently?
17-02-2009 1:07 PM
18-02-2009 11:37 AM
18-02-2009 11:22 PM
25-02-2009 6:09 PM
After numerous restarts of the router, SNR set at the exchange increased to 15dB, therefore reducing sync to around 1800kps, and ip profile to 1500kbps, which reflected in only being able to download at this rate.
However a week later my sync speed is back to around 2400 kbps with an ip profile of 2000 kbps, but again, max download is still capped at around 1700 kbps, I really can't work this out, is there any one out there that can shed some light on this.
PS for your info, I know I can download at higher speeds on this line as I have in the past.
Dave
25-02-2009 8:18 PM
26-02-2009 9:47 AM
I have asked plus.net/BT to reset my SNR to aid further testing, however there seemed to be an issue with this, and it looks like it is being investigated by their suppliers, so maybe they have found some fault after all.
Dave
26-02-2009 9:28 PM
What's the best speeds you've had? Do you know what the target SNRM was then?
Can you / have you heard any crackling or other intermittent noises on your line?
