Limited Connectivity
- Re: Limited Connectivity
11-08-2013 12:06 PM
I am running Windows 8 and it says the connection is "Limited". This problem usually resolves itself within a few minutes.
The problem really came to a head this morning when I could not get online for around 45 mins
Is there any fixes for this?
I wish I could offer more technical information, but I am a bit of newbie to this.
11-08-2013 2:18 PM
11-08-2013 5:56 PM
11-08-2013 6:31 PM
11-08-2013 10:56 PM
12-08-2013 9:10 AM
12-08-2013 9:40 AM
12-08-2013 9:47 AM
12-08-2013 2:14 PM
12-08-2013 2:49 PM
Perhaps try a different (newer) microwave and see if it makes any difference?
12-08-2013 3:42 PM
In windows 8, the limited wireless icon means you are connected to the router, but there is no internet connectivity, i.e. like OldJim suggested, the connection dropped. I see this when I disconnect the PPP session manually or when wireless goes up after rebooting it and before it reconnects to +net.
The only way he'd see a 169. IP address, is if he had a NIC wired to something, assuming there is one on his windows 8 PC, as it would take over from the un-associated Wifi interface.
A look at his connection graph would probably end the speculation
12-08-2013 3:47 PM
<img src="http://community.plus.net/visualradius/generated/image13763188013712.png"/>
12-08-2013 5:31 PM
13-08-2013 9:36 AM
