Limewire help
- Limewire help
Limewire help
05-01-2008 2:02 PM
Howdoo all
When i was on aosmell i could use limewire no probs but now i can and i cant it it totally random.
any one have the same problem?
Oh and surf is deactivated.
Message 1 of 3
(870 Views)
2 REPLIES 2
Re: Limewire help
05-01-2008 2:26 PM
Adjust your firewall settings... https://portal.plus.net/my.html?action=firewall
Do you need to do some port forwarding on you router?
Message 2 of 3
(234 Views)
Re: Limewire help
05-01-2008 2:45 PM
sorted thanks for the help mate
Message 3 of 3
(234 Views)
