Legacy Packages
- Legacy Packages
Legacy Packages
16-08-2008 10:02 PM
Hello,
I'm on Premier Option 1 from several years ago. I seem to go over the peak allowance every month (probably from BBC iPlayer) and I'm wondering if it is possible for me to upgrade to Premier Option 2 or 3, as I don't think they're offered anymore on the website? I don't fancy having my usage counted from 8am-midnight as is stated on the new packages. The one I am on only counts usage from 4pm-midnight which I would much prefer.
Thanks for any help,
Ryan
Ryan
Message 1 of 9
(1,710 Views)
8 REPLIES 8
Re: Legacy Packages
16-08-2008 10:16 PM
Premier Options 2 and 3 are legacy and are not generally available for upgrade. Premier Option 1 has 20Gb, with limits in place at 13 and 17Gb as well have a look at http://www.plus.net/support/broadband/products/archive/bb_premier1.shtml, are you sure Broadband Your Way Option 3 isn't better for you? 30Gb of usage for £19.99 so £2 less a month.
Have a look at http://usergroup.plus.net/070920_bbywcomp3.php there are significant improvements on download speeds at different times of the day. BBYW Option 3 is considerably better by the looks of it.
Maybe other people can comment as well?
Message 2 of 9
(601 Views)
Re: Legacy Packages
16-08-2008 10:28 PM
as Ryan said dont forget the different peak hour time from legacy to BBYW i.e. 1600-2400 an 0800-2400
Message 3 of 9
(601 Views)
Re: Legacy Packages
17-08-2008 2:47 AM
Yes, thanks for the help Emma, but if I work this out simply without going into too much detail, 20gb to use over 8 hours a day is a lot more than 30gb to use over 16 hours a day. Then if I was to create my own package it seems to really start to rack up in terms of cost. I'd be tempted to move away from Plusnet, as while I think they used to cater to heavy users, they seem to have dropped that in favour of being one of these horrid all-in-one service providers. I want a dedicated ISP, not someone offering me telephone, TV and god knows what else! Sorry about that rant, but I do genuinely think the state of broadband is going downhill.
Does anyone know if it is possible to get put on a legacy package?
[Moderator's note by Jonathan (chillypenguin): Full quote of preceding post removed, as per Forum Rules ]
Message 4 of 9
(601 Views)
Re: Legacy Packages
17-08-2008 1:37 PM
I suspect the clue's in the term "legacy package". My understanding is that Plusnet won't try to force a change in your contract, but if you choose to change your contract, then you will have to move to one of the current products. Otherwise, every package they've ever offered would be effectively a current package.
Message 5 of 9
(601 Views)
Re: Legacy Packages
17-08-2008 3:49 PM
Yeah, I was expecting as much John, but just wanted it confirmed. Thanks for the help everyone. Anyway, before I leave this thread, does anyone know of any other decent ISPs that will allow a similar package to the old ones offered by Plusnet?
Message 6 of 9
(601 Views)
Re: Legacy Packages
17-08-2008 11:10 PM
Quote from: hulls My understanding is that Plusnet won't try to force a change in your contract, but if you choose to change your contract, then you will have to move to one of the current products. Otherwise, every package they've ever offered would be effectively a current package.
As I said before terms and conditions work both ways. Some companies give you 30 days notice of a change in T&C and if you don’t reply in 30 days you have accepted the new conditions. Plusnet did treat me well when I asked to stay on my old contract.
puddy
Message 7 of 9
(601 Views)
Re: Legacy Packages
18-08-2008 2:48 PM
Hi Ryan,
I've got a flashing red button that I can press at this end if you'd like to move onto one of the other legacy packages.
Drop me a PM with the details and I'll get it sorted for you.
Message 8 of 9
(601 Views)
Re: Legacy Packages
18-08-2008 3:56 PM
Thank you James, I've sent you a PM.
Message 9 of 9
(601 Views)
