Lease time (F.A.O. Chris Pettitt)
- Lease time (F.A.O. Chris Pettitt)
Re: Lease time (F.A.O. Chris Pettitt)
18-11-2012 6:28 PM
Quote from: Anotherone These will be a high proportion of the ticket/calls.
I bow to your knowledge on such matters.
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
18-11-2012 8:18 PM
Quote from: Anotherone Getting a resync without rebooting or power cycling would be the way to find out if you really want to know, but as you may not wish to do that for obvious reasons make a note of your sync speed and keep a careful watch. If/when you see a change in sync speed, checl if the WAN time has been reset.
Yes, that always happens (WAN time reset when sync speed changes). My sync speed was constant during the 900 odd hours and has never been quite as good since! I'll try the gateway hop but I have to do that during daylight hours as my SNR drops by about 2dB after dark.
18-11-2012 9:05 PM
Gateway hopping dropping PPPoA shouldn't affect your sync but I can understand why you don't want to risk it until daylight.
18-11-2012 10:36 PM
Quote from: Anotherone make a note of your sync speed
These? :-
US Trained Rate: 440 kbps
DS Trained Rate: 4010 kbps
19-11-2012 5:57 AM
Just sort out your internal wiring as per the thread on that topic.
19-11-2012 6:45 AM
Quote from: Anotherone Yes those are sync speeds.
Thank you.
They are still exactly the same this morning. No drop outs since :Nov 17 11:39:46 and I'm still using the plug-in internal extension.
19-11-2012 8:29 AM
19-11-2012 10:23 AM
19-11-2012 10:39 AM
Quote from: Anotherone See my comments on your extension wiring thread.
You are "muddying the waters" by taking the problem over to another thread.
19-11-2012 10:41 AM
Quote from: ReedRichards there is no (maximum) lease time associated with a PPP session.
Have we proved there is no minimum either? Or should that be a minimum of zero?
19-11-2012 10:46 AM
If having the same IP address is important you can have a static one for a one off fee.
19-11-2012 10:52 AM
Quote from: Chris As far as I'm aware
Yes, thanks; I think I acknowledged your assumption.
19-11-2012 10:55 AM
Also, extending the IP lease time isn't going to stop a disconnection from happening, all that would do is reassign the same IP after you've reconnected.
19-11-2012 10:57 AM
Quote from: Chris If having the same IP address is important you can have a static one for a one off fee.
Were do I find details on this please? It wasn't available last time I looked.
p.s. Looks as if connection has dropped again.
19-11-2012 10:57 AM
