Latency through ipv6 tunnel
- Re: Latency through ipv6 tunnel
20-09-2008 11:17 AM
As there's no native ipv6 with plusnet, I'm running an aviya tunnel through to SIXXS.
Noticing it got a bit slow each evening, I thought I'd graph it for a while:
There's not too many enabled right now, but if I hit an ipv6 site in the evening, the navigation is a little frustrating.
I'm assuming this is network management kicking in... any chance of bumping the priority of aviya tunnels up a bit?
Message 1 of 7
(1,716 Views)
6 REPLIES 6
20-09-2008 11:36 AM
Can you do a trace through the tunnel and one in the clear please when you see these slow downs?
Is that possible for you to do?
Message 2 of 7
(634 Views)
20-09-2008 1:17 PM
Can do - won't be in tonight when it slows down, so I've just started recording a few things every 5 minutes:
traceroute6 www.sixxs.net
traceroute www.sixxs.net
traceroute6 2a01:348:6:12b::1 (tunnel endpoint - what's being graphed above)
traceroute gblon02.sixxs.net (ipv4 endpoint of the tunnel)
Let me know if you need anything else and I'll add it in.
Message 3 of 7
(634 Views)
21-09-2008 1:35 PM
OK, got some from lastnight, the following were all at 00:05:
traceroute to www.m.sixxs.net (2001:838:1:1:210:dcff:fe20:7c7c) from 2a01:348:6:12b::2, 30 hops max, 16 byte packets
1 * gw-300.lon-02.gb.sixxs.net (2a01:348:6:12b::1) 2521.74 ms 2927.01 ms
2 ae0-1235.rt2.the.uk.goscomb.net (2a01:348:0:4:0:3:0:1) 3007.38 ms 3306.99 ms 4201.29 ms
3 ge-0-0-0-1368.rt1.nik.nl.goscomb.net (2a01:348::10:1:1) 4435.88 ms 4506.71 ms 4551.8 ms
4 * ams-ix2.ipv6.concepts.nl (2001:7f8:1::a501:2871:2) 2540.8 ms 2061.62 ms
5 2001:838:0:13::1 (2001:838:0:13::1) 1778.17 ms 2088.61 ms 2558.86 ms
6 2001:838:0:12::2 (2001:838:0:12::2) 2203.32 ms 2310.85 ms 2701.73 ms
7 noc.sixxs.net (2001:838:1:1:210:dcff:fe20:7c7c) 2997.8 ms 2982.38 ms 2639.79 ms
traceroute: Warning: www.sixxs.net has multiple addresses; using 193.109.122.244
traceroute to www.m.sixxs.net (193.109.122.244), 30 hops max, 40 byte packets
1 10.2.10.2 (10.2.10.2) 1.078 ms 1.049 ms 0.963 ms
2 lo0.plusnet.thn-ag1.plus.net (195.166.128.101) 33.221 ms 34.909 ms 35.163 ms
3 vl703.thn-gw1.plus.net (84.92.4.241) 33.357 ms 39.160 ms 35.335 ms
4 195.66.226.185 (195.66.226.185) 36.683 ms 35.401 ms 35.371 ms
5 te8-7.ccr01.ams03.atlas.cogentco.com (130.117.0.197) 43.778 ms 43.600 ms 41.189 ms
6 vl3490.mpd01.ams03.atlas.cogentco.com (130.117.3.106) 46.975 ms 42.207 ms 48.659 ms
7 cogent-1101.xe-0-0-0.jun1.kelvin.network.bit.nl (149.6.128.154) 42.322 ms 48.057 ms 44.011 ms
8 nlede01.sixxs.net (193.109.122.244) 45.969 ms 52.570 ms 43.139 ms
traceroute to 2a01:348:6:12b::1 (2a01:348:6:12b::1) from 2a01:348:6:12b::2, 30 hops max, 16 byte packets
1 gw-300.lon-02.gb.sixxs.net (2a01:348:6:12b::1) 2169.6 ms 2227.38 ms 2316.1 ms
traceroute to gblon02.sixxs.net (77.75.104.126), 30 hops max, 40 byte packets
1 10.2.10.2 (10.2.10.2) 1.036 ms 0.973 ms 0.950 ms
2 lo0.plusnet.thn-ag1.plus.net (195.166.128.101) 34.105 ms 38.506 ms 35.297 ms
3 vl703.thn-gw1.plus.net (84.92.4.241) 36.803 ms 36.026 ms 39.832 ms
4 ae0-461.rt0.sov.uk.goscomb.net (195.66.226.226) 34.780 ms 35.768 ms 37.849 ms
5 ae0-1624.rt2.the.uk.goscomb.net (77.75.109.161) 37.601 ms 35.388 ms 35.664 ms
6 gblon02.sixxs.net (77.75.104.126) 35.239 ms 36.579 ms 34.321 ms
Message 4 of 7
(634 Views)
22-09-2008 6:18 PM
Hi James.
Yip prettly high response times evident there through the tunnel.
Can I ask what port (s) you are using for the Avaya client?
If it is not a standard VPN port is it possible for you to change this?
I've looked at the Avaya support info and trying to get a handle on which port (s) it uses is not proving to be easy.
I want to ensure that our traffic management is correctly identifying the ports in use as VPN, providing they are in the standard VPN range that is
Alernatively, a Wireshark capture of the traffic might help identify its classification.
Message 5 of 7
(634 Views)
23-09-2008 5:57 PM
Oops, it's ayiya, not aviya... and nothing atall to do with avaya. lol
All open, so plenty of documentation:
http://www.sixxs.net/tools/ayiya/
I could get you a capture, but I should imagine the draft will be easier to interpret...
Message 6 of 7
(634 Views)
23-09-2008 8:54 PM
Doh. I need to learn to read properly.
Thats much more to go on. I'll get someone to take a look at this tomorrow.
Message 7 of 7
(634 Views)
