Latency Spikes on the home network
stamford43e
I'm experiencing latency spikes on my broadband connection.  When ping something on the internet (8.8.8.8), every minute or so a packet would take around 500ms to return. I thought it might be a problem on the internet but then tested it with a ping to the home router 192.168.1.254 and got the same.  Wifi or Ethernet, same result.
If I reboot the router the problem goes away but then next time I go to play online games (so the next evening) its back and requires another reboot.  Obviously I don't want to have to reboot my router every day.
The router is a Hub One with firmware '4.7.5.1.83.8.263'  Is this the most recent?
It is possible that another device is causing this but I feel like the router should be able to handle this which is why I'm thinking it is either faulty or has a bug in the firmware.
1 REPLY 1
Fixes: 419
Re: Latency Spikes on the home network
@stamford43e
xxx.263 is the latest firmware.
Yes it has bugs. You can read through the router board to get a view of these.
