Kindle has stopped seeing wi-fi connection
- Kindle has stopped seeing wi-fi connection
29-04-2012 1:14 PM
As stated above. This morning I can't connect to my router with the kindle. There has been no problem for the last few months since I had it.
It just says "no wi-fi networks are found."
I don't know if its a kindle fault or my broadband fault. I am connected on my pc with no problem. So I thought I'd ask here first.
Message 1 of 5
(1,671 Views)
4 REPLIES 4
Re: Kindle has stopped seeing wi-fi connection
29-04-2012 2:18 PM
I would suggest you download a program called inSSIDer which will show you the wireless networks in your vicinity, the strength of signal and lots more
You can get here (its free) http://download.cnet.com/inSSIDer/3000-18508_4-10848357.html
Message 2 of 5
(579 Views)
29-04-2012 2:22 PM
Hi
Log into your router (http://192.168.1.254 if it is supplied by plusnet, and make sure the wireless channel is from 1 to 10
Ian
Ian
Message 3 of 5
(579 Views)
29-04-2012 2:27 PM
Got on the page but I don't know what to look for. It says under wireless Unknown f0-a2-fc-aa-05 and under that it says Unknown f0-02-25-a2-1d-92
Thanks for your help.
Message 4 of 5
(579 Views)
29-04-2012 3:59 PM
Been on to Kindle help and they had me press the button on my router and reset my kindle to factory setting and it worked. They think that my isp plusnet must have sent an update to the router that caused this to happen. I don't know.
Aft least I can connect now. Thanks.
Message 5 of 5
(579 Views)
