Keep losing Internet
- Keep losing Internet
08-12-2009 10:49 AM
Re: Keep losing Internet
08-12-2009 11:27 AM
08-12-2009 3:16 PM
I am never disconnected from the LAN, only the Internet.
Can be annoying if i am uploading or online gaming. Always seems to happen at the same time though, either mid afternoon or around midnight.
08-12-2009 3:52 PM
If it continues to happen regularly, raise a fault at http://faults.plus.net and we can look into it.
08-12-2009 4:00 PM
Quote from: mPH Does anyone have an idea what might be going wrong. I keep losing Internet, went for about half an hour last night and then is fine again. I never loose the connection with the router so thats not a problem...
Check my thread "connection falls out" seems to be the same thing although we have no checked at midnight.
08-12-2009 11:23 PM
Lost it tonight again at 11, for about 20 minutes. Checked router and was all okay, all lights were the same as when i have a connection. This is really annoying now.
09-12-2009 9:44 AM
Quote all lights were the same as when i have a connection
Very odd, I would have at least expected the Internet light to go out, if not the DSL one too.
I can see that you had no connection last night around the times you say, so the router keeping the lights as they were is odd and shouldn't be happening.
Have you tested in the master socket and kept the router plugged in there to see if the connection stays stable or continues to randomly drop out?
09-12-2009 1:47 PM
09-12-2009 7:44 PM
Do you see any problems in hows its set up?
09-12-2009 7:54 PM
09-12-2009 8:17 PM
09-12-2009 8:25 PM
i had a big out a few days ago and when it came back it was really fast, even at peak so i came here and saw the capacity increase info so was really pleased.
since then, and on a couple of occasions my connection has gone wierd.
1st time the internet light dropped and came back a while later. since then the light has not dropped but i am getting problems (like right now). i can of course visit plusnet as i am here, google is fine and yahoo and others i have tested. but then equally lots of other sites just wont load. i have tried rebooting (when it happened earlier today) and it made no difference, but it came back a few minutes later anyway.
i had got used to a slow but useable connection until the upgrade, and now i have a fast but it appears unreliable connection now.
any thoughts?
09-12-2009 8:26 PM
09-12-2009 8:29 PM
However - It's just not done to connect into the cable with a junction box before it gets to your master socket. If you end up having to call out BT for a fault the engineer will start by ripping that extension out, then probably take it from there. If someone has connected in to the incoming cable then who knows what else they have done to the wiring?
Do you feel confident removing the front of that junction box and seeing if it is just one pair of wires that split to the extension at the top of your diagram. And if so how do you feel about disconnecting that pair which feeds the extension and extending that pair back to the master socket?
Also if there are loads of wires connected in the junction box and not just one pair splitting 3 ways, or if this just isn't making sense then do you know how to attach photo's to any replies? A picture of the inside of the junction box and the back of the master socket faceplate could help us help you.
09-12-2009 10:12 PM
