Keep getting kicked from battlefield 3
- Keep getting kicked from battlefield 3
- « Previous
- Next »
Re: Keep getting kicked from battlefield 3
05-07-2013 5:27 PM
If you could also get a traceroute as discussed from both line, it may be easiest you use MTR. You can download here, you'd need to traceroute to 85.236.100.92
05-07-2013 5:28 PM
Plusnet:
C:\Users\Dave>tracert 85.236.100.220
Tracing route to blade10-100-220.multiplay.co.uk [85.236.100.220]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 28 ms 15 ms 14 ms lo0-central10.pcl-ag02.plus.net [195.166.128.183
3 14 ms 14 ms 14 ms link9-central10.pcl-gw01.plus.net [84.93.249.48]
4 17 ms 14 ms 14 ms 196.core.access.plus.net [212.159.0.196]
5 14 ms 14 ms 14 ms ae1.ptw-cr01.plus.net [195.166.129.0]
6 21 ms 14 ms 14 ms ae2.ptw-cr02.plus.net [195.166.129.5]
7 14 ms 15 ms 14 ms 195.66.236.224
8 14 ms 14 ms 14 ms blade10-100-220.multiplay.co.uk [85.236.100.220]
Trace complete.
BT:
2 12 ms 11 ms 11 ms 217.32.147.110
3 11 ms 12 ms 11 ms 217.32.147.174
4 16 ms 16 ms 15 ms 212.140.206.98
5 15 ms 15 ms 15 ms 217.41.169.231
6 16 ms 15 ms 17 ms 217.41.169.109
7 15 ms 15 ms 15 ms 109.159.251.205
8 28 ms 31 ms 25 ms core1-te0-0-0-6.ilford.ukcore.bt.net [109.159.25
1.157]
9 24 ms 23 ms 23 ms core4-pos0-1-5-0.telehouse.ukcore.bt.net [195.99
.125.225]
10 25 ms 26 ms 26 ms 194.74.65.58
11 26 ms 26 ms 23 ms te5-2.gs1.core.enta.net [188.39.127.71]
12 23 ms 23 ms 24 ms te1-1.interxion.core.enta.net [188.39.127.72]
13 24 ms 21 ms 24 ms gi4-3.enta-transit.as35028.net [84.45.252.122]
14 24 ms 24 ms 31 ms blade10-100-220.multiplay.co.uk [85.236.100.220]
Trace complete.
05-07-2013 5:28 PM
05-07-2013 5:33 PM
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.0.1 - 0 | 51 | 51 | 0 | 0 | 2 | 0 |
| lo0-central10.pcl-ag02.plus.net - 0 | 51 | 51 | 14 | 22 | 127 | 23 |
| No response from host - 100 | 10 | 0 | 0 | 0 | 0 | 0 |
| 196.core.access.plus.net - 0 | 51 | 51 | 13 | 15 | 47 | 13 |
| ae1.ptw-cr02.plus.net - 0 | 51 | 51 | 14 | 15 | 37 | 17 |
| 195.66.236.224 - 0 | 51 | 51 | 14 | 32 | 196 | 15 |
| lon052.multiplay.co.uk - 0 | 51 | 51 | 14 | 14 | 17 | 14 |
|________________________________________________|______|______|______|______|______|______|
WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
BT:
| WinMTR statistics |
| 192.168.0.1 - 0 | 52 | 52 | 0 | 0 | 1 | 0 |
| 217.32.147.174 - 0 | 52 | 52 | 11 | 15 | 79 | 11 |
| 109.159.251.205 - 0 | 52 | 52 | 15 | 15 | 20 | 15 |
| 195.99.125.86 - 0 | 52 | 52 | 23 | 25 | 38 | 26 |
| te1-1.interxion.core.enta.net - 0 | 52 | 52 | 20 | 23 | 36 | 23 |
| gi4-3.enta-transit.as35028.net - 0 | 52 | 52 | 21 | 55 | 235 | 23 |
| lon052.multiplay.co.uk - 0 | 52 | 52 | 20 | 22 | 27 | 23 |
08-07-2013 5:20 PM
When you get the disconnections would you be able to run a wireshark so we can see exactly what is happening at the time?
10-07-2013 12:01 AM
Dave
10-07-2013 10:16 AM
10-07-2013 1:29 PM
I'm going to pull everything apart here to see if I can identify anything my end again.
10-07-2013 1:34 PM
I'll update you when this has been done.
12-07-2013 1:14 PM
There is other traffic going on while you're gaming, are you aware of that?
Do you always play on the same game server? If so, would you be able to try an alternative one?
If you're able to capture another wireshark and capture the time of the disconnection(that would include minute and to the nearest few seconds if possible) it would help us trying in trying to pinpoint this.
14-07-2013 2:54 AM
I'm aware of the other traffic. I think I have actually solved the issue I think. It needed some extra care with port forwarding port 80 across the 2 lines to different machines. I've not been kicked since I made the changes.
fingers crossed.
Dave
- « Previous
- Next »
