Keep getting kicked from battlefield 3
- Keep getting kicked from battlefield 3
04-07-2013 9:27 AM
I'm on the fibre unlimited and keep getting kicked from battlefield 3 for some reason with a no packet flow error for punkbuster. If I switch to my BT line it all works fine and dandy. I have tried turning gaming mode on, disabling the firewall, forwarded all ports, making the router pingable, DMZ, removed the Plusnet router completely and disabled the firewall in the Plusnet CP.
I normally run load balanced, with 2 fibre lines into a Draytek 2920. I'm pretty savvy and have worked in IT previously. If I get these errors and switch off the Plusnet line and switch to the BT one it works flawlessly but this is disrupting other work stuff on the BT line. I also want to use the Plusnet line as it has a better ping :).
I'm running with the 2 fttc modems directly into the Draytek for my everyday operations.
Does anyone have any idea or have experienced this on Plusnet? What did you do to resolve it? I have done the reinstalls and all that malarkey and if it was that it wouldn't work on the BT line.
Dave
Re: Keep getting kicked from battlefield 3
04-07-2013 9:34 AM
Can you do a speed test on the BT speed tester and let us know what your line profile is set to. I think our profile is set too high and this is causing QoS problems.
http://speedtest.btwholesale.com/
Ex-Broadband Service Manager
04-07-2013 9:59 AM
For your connection, the acceptable range of speedsis 16 Mbps-48.22 Mbps .
Additional Information:
IP Profile for your line is - 48.22 Mbps
I think it has been as high as 50 but that's about it. Come to think about it I often get slight stalls opening web pages, could this be related? I put it down to the plusnet DNS.
Dave
04-07-2013 10:01 AM
Dave
04-07-2013 10:01 AM
04-07-2013 10:03 AM
04-07-2013 10:05 AM
04-07-2013 10:20 AM
Dave
04-07-2013 10:21 AM
04-07-2013 10:24 AM
04-07-2013 10:38 AM
04-07-2013 10:54 AM
04-07-2013 10:57 AM
(for reference, you are connected to ptn-ag04.plus.net)
04-07-2013 11:04 AM
Dave
04-07-2013 11:05 AM
The drops you can see in the graph below, are they initiated by you? (I know the ones today have been.)
<img src="http://community.plus.net/visualradius/generated/image13729322579048.png"/>
