Just upgraded to premium. A couple of questions.... Ticket raised - 31638277
- Just upgraded to premium. A couple of questions......
19-01-2010 11:00 AM
I know this info is out there somewhere but I can't find it again (after a year or more).So before I go hassling support.....
1/. I've just upgraded from the old 2 Mbit Premier to the latest Premium service.I've been billed but my line speed is still reading as 2 Mbit although the rating is for around 4 Mbit. Is this just my profile setting at Plusnet or do I have to wait for all the BT stuff to happen? I requested the change a while ago now but it's just happened on my billing date.
2/. I've got a static IP and would like to keep it if possible.Do I need to ask for this to happen?
Ta in advance.
Ta in advance.
Message 1 of 6
(1,087 Views)
5 REPLIES 5
Re: Just upgraded to premium. A couple of questions....
19-01-2010 11:12 AM
You may still be on the fixed speed service as changing products won't necessarily change that.
Easy way to check is the upstream speed reported by your router - if it isn't 448kbps then you aren't on the up to 8Mb service
Message 2 of 6
(529 Views)
19-01-2010 11:28 AM
Thanks Jim,
Just checked and am still on 288 kbps upwards and 2272 kbps downwards so I'd guess nowt has changed on my profile except the reduced fees.
I found out that I'll keep my static IP and huge website space from the legacy product but being a bit senior I've lost the link.
I'm not in a great rush but would like to try the HD streaming from iplayer.
Message 3 of 6
(529 Views)
19-01-2010 11:30 AM
Either raise a ticket asking to go onto Max or wait for a Comms member to pick it up
Message 4 of 6
(529 Views)
19-01-2010 12:30 PM
Thanks again Jim. I'll go raise a ticket.
(Ticket raised - 31638277 )
Message 5 of 6
(529 Views)
Re: Just upgraded to premium. A couple of questions.... Ticket raised - 31638277
21-01-2010 9:55 AM
In the absence of any reply on my ticket after two days......
bumpety bump.
Please.Should be an easy one to sort out guys.
bumpety bump.
Message 6 of 6
(529 Views)
