Just switched to plusnet and have lost internet after 4 days.
- Just switched to plusnet and have lost internet af...
- « Previous
- Next »
Re: Just switched to plusnet and have lost internet after 4 days.
16-05-2012 4:04 PM
Actually, on Saturday, after it being down for a couple of days I tried an old router that my mam had from when she was on Orange broadband. I didn't have login details for it but hooked it up assuming it would just sync automatically. It didn't work, but could this have caused my problems to get worse?
And the BT test login does work, but as I mentioned a couple of times while on the phone, it doesn't work every time. It sometimes takes me hitting 'Apply' 3 times before it connects with BT test login.
16-05-2012 5:27 PM
Quote but could this have caused my problems to get worse?
I can't see how to be honest however by default the firmware on those routers is locked down to only allow a connection to orange so it wouldn't prove anything unfortunately.
17-05-2012 9:02 AM
Router was reset before I tried it, and I couldn't get an internet connection with it. I got a connection using the bt_test@startup_domain username, but again couldn't get one using the bt_test_user@plusdsl.net username. The router was telling me I had authentication problems.
So where do I go from here?
17-05-2012 9:18 AM
Otherwise this must be a problem with translation between Sheffield and Mumbai
17-05-2012 9:20 AM
17-05-2012 9:43 AM
Quote I got a connection using the bt_test@startup_domain username, but again couldn't get one using the bt_test_user@plusdsl.net username
That really does look like the BT RAS is not configured properly and its not accepting the plusdsl.net domain for this line. What confuses me slightly is that Adam said PlusNet could see authentications for bt_test@startup_domain. I would have thought that authentication for the startup_domain would go to the BT Radius rather than PlusNet, or is it different on 21CN WBC?
Surely though, if it is just a BT RAS configuration error, someone at PlusNet should have been able to check the BTw configuration fairly easily...
So maybe I'm talking rubbish!.
17-05-2012 9:46 AM
17-05-2012 10:01 AM
Quote So where do I go from here?
Sorry to hear there's still an issue with this, from what I can tell this does look like a problem that we may be able to push our suppliers to fix remotely, i.e without the need for an engineer visit. The fault is with a priority team here now so I'll make sure we do what we can to push things in the right direction today. I'd advise keeping an open mind about an engineer visit as sometimes they are needed as a matter of course to allow us to escalate faults further with BT wholesale.
I'll make sure I keep you posted about this today.
17-05-2012 10:02 AM
17-05-2012 10:19 AM
Plusnet: Have you investigated this possibility?
17-05-2012 11:01 AM
17-05-2012 1:09 PM
17-05-2012 1:33 PM
Thanks to everyone who replied and offered help/suggestions.
- « Previous
- Next »
