Just ordered Fibre - whats the best router to get
- Just ordered Fibre - whats the best router to get
04-01-2014 6:21 PM
Looking to invest in a better router than the cr*p plusnet will provide. Want a single device so a combined modem and router - any suggestions? Been looking at BT Home Hub 5 as an idea.
Message 1 of 8
(2,251 Views)
7 REPLIES 7
Re: Just ordered Fibre - whats the best router to get
09-01-2014 12:19 PM
Hi i can recommend the Draytek Vigor 2850n using currently, new model Draytek Vigor 2860n both support VDSL2.
Message 2 of 8
(1,403 Views)
09-01-2014 1:11 PM
I've been very happy with the Asus RT-N66U router. Has some great speeds across the property and maintains a high throughput even at the extremities of it's range.
Simple to set up too, but does allow some geeking out for QOS and traffic management. If that's your thing. 😉
http://www.asus.com/Networking/RTN66U/
Message 3 of 8
(1,403 Views)
09-01-2014 1:59 PM
Another vote for the RT-N66U here, great bit of kit!
Message 4 of 8
(1,403 Views)
09-01-2014 2:18 PM
If you are looking for 1 box the Asus DSL-N66U... This is the RT-N66U router with a modem built in (ADSL and VDSL)...
Message 5 of 8
(1,403 Views)
09-01-2014 2:26 PM
BT HomeHub 5
Message 6 of 8
(1,403 Views)
09-01-2014 3:22 PM
AVM Fritz!Box Fon WLAN 7390
http://www.thinkbroadband.com/hardware/reviews/73-fritzbox-7390.html
Call me 'w23'
Message 7 of 8
(1,403 Views)
09-01-2014 7:36 PM
Asus rt n66u - awesome wfi range
The dsl version is not the same router with a modem built in. The cpu is different.
Message 8 of 8
(1,403 Views)
