Just joined from BE - ping spikes making gaming unplayable
- Just joined from BE - ping spikes making gaming un...
Re: Just joined from BE - ping spikes making gaming unplayable
13-09-2013 12:44 PM
15-09-2013 11:08 AM
16-09-2013 8:03 AM
16-09-2013 8:11 AM
16-09-2013 8:15 AM
16-09-2013 11:21 AM
16-09-2013 4:41 PM
Are you able to run a traceroute?
16-09-2013 5:40 PM
Interesting - my guess is the download traffic (which was a re-installation of StarCraft II, a sad tale of bad ping times, attached) is key somehow, as if it's not being prioritised correctly. A quick Google implies it uses BitTorrent.
17-09-2013 8:35 AM
Download speedachieved during the test was - 4.58 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :5.86 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 5 Mbps
Is the PN profile still at 4.5Mbps? If so, could that be what's causing the problem?
17-09-2013 8:58 AM
it made the game totally unplayable for a lot of people regardless of ISP due to monster ping times and frequent dc's caused by dropped packets....
if your getting the same problem on other games then its possible its a connection issue locally but an ip profile that's lower than your connection speed shouldn't cause problems it just limits the maximum bandwidth on your line, the only time it would likely cause a problem is if your ip profile was higher than your sync speed and your connection was unable to handle whats trying to come through ......
whatever the cause of the issue I hope you get it fixed, trying to enjoy your online experience to be suffering constant lag spikes is a nightmare
17-09-2013 9:43 AM
As you can imagine, 6 months and no resolution is immensely frustrating.
17-09-2013 9:46 AM
Let's get a fault raised and see if there is something else going on there. Can you raise on via http://faults.plus.net
Ex-Broadband Service Manager
17-09-2013 9:56 AM
17-09-2013 10:10 AM
17-09-2013 10:26 AM
