Just joined from BE - ping spikes making gaming unplayable
- Just joined from BE - ping spikes making gaming un...
Re: Just joined from BE - ping spikes making gaming unplayable
26-07-2013 8:01 PM
29-07-2013 10:59 AM
I've had to set the profile to 45000kbps to match the BT profile.
I've not been able to read the full history of this thread I'm afraid but I'm noticing a resynch almost exactly every two days, is that anything that you're doing yourself?
Adam
29-07-2013 11:20 AM
Uptime: 2 days, 12:16:21
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 5.216
Data Transferred (Sent/Received) [GB/GB]: 1,27 / 1,99
Output Power (Up/Down) [dBm]: 12,4 / 19,9
Line Attenuation (Up/Down) [dB]: 22,0 / 33,5
SN Margin (Up/Down) [dB]: 13,0 / 12,2
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 7.066 / -
FEC Errors (Up/Down): 2 / 8.281.004
CRC Errors (Up/Down): 4 / 106
HEC Errors (Up/Down): - / 106 / 1.914
29-07-2013 12:17 PM
29-07-2013 3:25 PM
However......although I appreciate your very timely support, I'm getting frustrated that we have to do this little dance every time the line resyncs. There must be away to fix this, and there must be others in the same position as I. What can I do to get this resolved permanently? Should I raise a ticket you can file a bug report against?
29-07-2013 4:03 PM
I'll check where we were at with it.
Ex-Broadband Service Manager
30-07-2013 8:39 AM
07-08-2013 10:31 AM
31-08-2013 8:09 AM
Thanks.
02-09-2013 1:06 PM
02-09-2013 2:43 PM
Triggering event was a router power-cycle as it was hung. It behaved as it has in the past, by negotiating a 7Mbit link initially, then slowly dropping that over a period of days. It's currently at 6Mbits, and I expect that to drop back to 5-ish at some point, so best to leave it where it is at the moment.
05-09-2013 6:26 PM
Thanks.
06-09-2013 10:15 AM
It'd dropped down to 4500 again so I've matched that on our side to sort the prioritisation, hope it's had the desired effect?
06-09-2013 10:50 AM
Any progress on a permanent fix? I've had this for nearly 6 months now.
07-09-2013 7:58 AM
Download speedachieved during the test was - 4.58 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :5.41 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 4.5 Mbps
I'm getting very frustrated with this.
