Just joined from BE - ping spikes making gaming unplayable
- Just joined from BE - ping spikes making gaming un...
Re: Just joined from BE - ping spikes making gaming unplayable
17-04-2013 12:45 PM
It will do it automatically but doing that manually may speed the process up.
17-04-2013 12:51 PM
How do we stop it happening again?
17-04-2013 12:59 PM
18-04-2013 11:30 AM
What is the delta (difference?) report in any case? How often can I expect this to happen if we don't do anything?
18-04-2013 11:49 AM
It would only update if your connection drops sync.
21-05-2013 8:30 PM
22-05-2013 11:03 AM
I've changed your profile to match, I'll take a look into this to see if there's anything that can be done. I know Chris Pettitt was looking into this too, I'll catch up with him.
22-05-2013 1:25 PM
30-05-2013 8:26 AM
Thanks.
30-05-2013 3:38 PM
It's at 4500 on BTs side but 7150 on ours, so that won't be slowing anything down at all. Unless you mean you'd like them to match, in order that the traffic prioritisation works correctly?
EDIT: I've matched the profile on our side to 4500 after receiving instructions
30-05-2013 10:31 PM
However - I'm confused. Not tricky, I'll admit. I was referring to the the profile that controls the traffic prioritisation used which (I assumed, possibly incorrectly) was unrelated to line speed. However, mention of 4500 and 7150 and you saying 'slowing anything down' makes me think you're fiddling with something that controls ADSL line speed, not traffic prioritisation. Can you explain or point me at some documentation that explains?
31-05-2013 9:10 AM
http://community.plus.net/forum/index.php/topic,113085.msg971625.html#msg971625
Make sense?
Matt just confused stuff by getting the wrong end of the stick when seeing your latest post
Ex-Broadband Service Manager
05-06-2013 7:52 AM
Once again, can a PN admin please reset my PN speed profile? My lag whilst streaming has reappeared. Any progress on making this stick?
05-06-2013 9:46 AM
05-06-2013 10:19 AM
Strangely, we keep resetting your profile to 8000. This isn't normal, and might actually be a problem with the feed we are getting from BT.
I've pushed it back down and we are investigating.
