Just found my old Be* Stats From a Year Ago
- Just found my old Be* Stats From a Year Ago
31-03-2009 11:38 AM
I wonder if 21cn would produce a decent sync on my line like this . Taking into mind that this was a year ago .
Quote Uptime: 5 days, 0:18:50
Modulation: G.992.5 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,178 / 6,011
Data Transferred (Sent/Received) [MB/MB]: 2.96 / 32.87
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 30.0 / 54.5
SN Margin (Up/Down) [dB]: 6.0 / 5.0
Vendor ID (Local/Remote): TMMB / µ
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 38 / 0
FEC Errors (Up/Down): 0 / 558,411
CRC Errors (Up/Down): 9 / 894
HEC Errors (Up/Down): 18 / 298
Message 1 of 4
(879 Views)
3 REPLIES 3
Re: Just found my old Be* Stats From a Year Ago
31-03-2009 12:01 PM
That's a remarkbly high speed for the attenuation.
Don't forget that Be implement some extensions to ADSL2+ and to get the best you need to use their specific routers (or compatible ones) that talk properly to the DSLAM. Also did you have interleaving off?
Message 2 of 4
(374 Views)
31-03-2009 12:18 PM
Not sure how i obtained them but i got them , yes this was with interleave off , its hard to belive tbh ::). Router was their ST585v6 , i belive a broadcom chip (not 100% sure on that)
Message 3 of 4
(374 Views)
31-03-2009 12:32 PM
Quote from: markrach broadcom chip
It is, with extra features on INP (Impulse Noise Protection)
Message 4 of 4
(374 Views)
