JoJo Help!
- JoJo Help!
- « Previous
- Next »
Re: JoJo Help!
21-06-2012 1:18 PM
A great explanation Anotherone, thanks
Message 31 of 36
(270 Views)
Re: JoJo Help!
21-06-2012 2:31 PM
Matt
Thanks for the reply.
I wish someone would explain the whole SNR and Loop Att thing
In Engineering we have to change one thing at a time to find out what the issue is.
Your Engineer said that the Loop Att of 16.5 made him think that SNR needed to be reduced. He said this could be done at the exchange after the stabilisation period lockdown.
This seems completely at odds with what you say Matt
Something has changed since the intervention of S yesterday at 17:08, now the router will establish a connection below 8mb which at least means I get a connection but does not identify where the problem is.
Message 32 of 36
(270 Views)
Re: JoJo Help!
21-06-2012 6:17 PM
@Zap
Thanks for your time tonight.
I've updated your ticket with most of what we covered in our call. Apologies it looks a little messy in the presentation of it but I hope the overall message gets over :).
@Matt/Jo
FYI; I'm not back in office until Tuesday. I'm going to put further internal notes what I want doing on this case so when I come back its a case of we can pick up where we left off
@Matt/Jo
Message 33 of 36
(270 Views)
Re: JoJo Help!
22-06-2012 1:51 PM
Thanks Spencer
Just feels good that someone is on the case.
It seems to me that this whole SNR thing is about trying to find a config that works, you configuring it so that SNR could go as high as it liked made for a lower speed connection which worked more reliably as it kept connections below 8mb.
I got the new Router today and it seems to be more suited to the equipment at the exchange because it connected and seems to be at 440 / 14,081
We will monitor until you get back on Tuesday.
Thanks for your help!
Link Information
Uptime: 0 days, 0:34:52
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 440 / 14,081
Data Transferred (Sent/Received) [MB/MB]: 2.28 / 16.85
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 10.2 / 22.5
SN Margin (Up/Down) [dB]: 32.4 / 15.9
Loss of Link (Remote): -
Error Seconds (Local/Remote): 31 / 0
FEC Errors (Up/Down): 47 / 55,189
CRC Errors (Up/Down): 6 / 1,661
HEC Errors (Up/Down): 14 / 83,186
me: 0 days, 0:46:51
Data Transferred (Sent/Received) [MB/MB]: 3.10 / 21.84
SN Margin (Up/Down) [dB]: 32.2 / 15.9
Error Seconds (Local/Remote): 32 / 0
FEC Errors (Up/Down): 47 / 55,770
CRC Errors (Up/Down): 6 / 1,662
HEC Errors (Up/Down): 14 / 83,199
Link Information
me: 0 days, 0:46:51
Message 34 of 36
(270 Views)
Re: JoJo Help!
25-06-2012 1:07 PM
Message 35 of 36
(270 Views)
Re: JoJo Help!
25-06-2012 1:43 PM
Thanks JO
You are a star!
You are a star!
Message 36 of 36
(270 Views)
- « Previous
- Next »
