Its me again, with ANOTHER awful speed complaint!
- Its me again, with ANOTHER awful speed complaint!
Re: Its me again, with ANOTHER awful speed complaint!
09-09-2014 6:51 PM
Dan had to put a manual order in to BTw, so as we know they are not the most efficient organisation in the world, don't hold your breath
Joking apart, can we check a couple of other things whilst we are waiting for this to happen.
Is the filter plugged directly into the Master socket - no extension leads?
Is the modem/router plugged directly into the filter using it's original lead?
I asked if there were any other phone sockets in the flat other than the 3 that you've mentioned - in the part of it that used to be another flat? You didn't mention if there was.
09-09-2014 7:48 PM
09-09-2014 8:17 PM
Look out for these changes when the reset happens, as mentioned before -
SN Margin (Up/Down) [dB]: 6.5 / 15.5 ............ the 15.5 to change to 6 hopefully
Bandwidth (Up/Down) [kbps/kbps]: 1,155 / 4,216 .......... the 4,216 change to something nearer 10000 hopefully.
Is the modem/router that you have the TG585 or the TG582n?
09-09-2014 9:20 PM
09-09-2014 9:29 PM
09-09-2014 10:06 PM
Software Release: 8.2.7.8
10-09-2014 6:33 AM
10-09-2014 11:54 AM
I'm also placing a modify order to up cap your upstream now.
10-09-2014 12:06 PM
I think it'll be time to try another modem/router.
10-09-2014 1:42 PM
Interesting that the router seems to only want to sync at G.992.3 rather than 5, maybe it is a router issue... be useful to see the latest stats in more detail.
10-09-2014 2:05 PM
Of course the line may be a bit rubbish as well (or the Master socket knackered) but I'm not giving up hope based on that random 13M that was mentioned in another thread. Another modem/router will show if there's a need to get a fault investigation on the line/master socket.
There is another option to try possibly before that as far as the speed goes, but we'll see.
10-09-2014 5:58 PM
10-09-2014 6:08 PM
I wouldve considered borrowing a router but none of my neighbours or friends have spare routers i could use everyone i know is using the default router given by their ISPs unless theyre kind enough to go without internet for a few days which i doubt Lol! Is it possible for Plusnet to supply a router?
and stats are here:
Uptime: 0 days, 6:13:09
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,144 / 6,224
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,232
Data Transferred (Sent/Received) [MB/GB]: 133.69 / 2.56
Output Power (Up/Down) [dBm]: 12.5 / 19.0
Line Attenuation (Up/Down) [dB]: 21.5 / 36.5
SN Margin (Up/Down) [dB]: 27.0 / 6.0
Loss of Signal (Local/Remote): 589,818 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 786,451 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 2,658
HEC Errors (Up/Down): 11 / 2,404
UPDATE!: Did a speediest and I'm getting 5mbs now hmm
10-09-2014 6:43 PM
1. Best Effort Test: -provides background information.
Download Speed
4.05 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.05 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.5 Mbps
Upload Speed
0.03 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.03Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Getting poor upload speeds tho it seems hmm...
10-09-2014 6:55 PM
Quote from: MisterW Interesting that the router seems to only want to sync at G.992.3 rather than 5, maybe it is a router issue...
Is this actually a decision left to the router to make or is a service provision restriction / configuration? I synch on ADSL 2 only.
