Issues with new Thomson 585 v7
- Issues with new Thomson 585 v7
27-08-2010 6:49 PM
Is the interface on the Thomson supposed to be slow and clunky too, or is it just me?
Just looking at it again, it seems every time I reset the password, the router shuts itself down and factory reboots. Does this mean I can't actually change the password?
Also is it possible to change the SSID?
It's all very frustrating - grrrrrr!
Re: Issues with new Thomson 585 v7
27-08-2010 7:18 PM
27-08-2010 7:43 PM
27-08-2010 7:49 PM
Edit..Typo
27-08-2010 8:18 PM
I too would love to be able to change my password, SSID, etc.
I'm still waiting for someone from PN to reply. I know they've been a bit busy today so am waiting patiently.
27-08-2010 8:22 PM
27-08-2010 10:04 PM
Quote from: Snarf Just got this through the post today, plugged it in and away we go. Thought I'd change the password to something more memorable for me, however it keeps reverting to its old password? It'll accept my new password maybe once, then revert. Also within the first 45mins whilst connected with 6dB SNR downstream, it suddenly disconnected, then reconnected. I'm struggling to see how this is an improvement over my Netgear DG834Gv3 that I was told didn't "officially" support ADSL2, so was sent out the Thomson by PN.
Have you upgraded the DG834G v3 with the most recent official UK firmware > link
27-08-2010 11:03 PM
29-08-2010 3:31 PM
I am not sure if it is a poor router or poor firware.
30-08-2010 10:39 AM
The web i/f has been slow and clunky on every firmware revision I've tried, and on 3 different sets of hardware.
If you look on ebay, you'll see them being sold for as little as £3.50 including P&P, which I think gives you an idea of how highly they're valued! A huge difference to the prices the BT 2wire routers go for.
I've had terrible issues with the Thomson's, including:
- Rebooting when used with a lenovo laptop (which did get fixed so at least it didn't reboot, thanks to a new build from Bob Pullen)
- Deciding to disable the internet connection in a way that can only be re-enabled using the CLI anytime you change anything in the web i/f
- Blocking PPTP VPNs, the only fix for which seems to be to reload the version that reboots with the lenovo's, and even that doesn't seem to fix the VPN (works fine with a netgear though)
plus.net have now told me mine is out of warranty, so if I want a fixed router then I'll need to pay - but the "fixed" new router will still be supplied with the same broken firmware. (!)
One has already gone in the bin and been replaced with a Vigor 2820n. I think the other ones are about to go the same way (though any suggestions for a good router welcome!).
30-08-2010 5:56 PM
The only positive is that it is slightly more stable than my Netgear, though it has done a couple of random reboots whilst having a decent SNR.
31-08-2010 11:54 AM
I have just replied to your ticket. Hope that helps.
Jojo
31-08-2010 12:00 PM
the issue with windows 7 is a well documented one and not just specific to thomson routers. However, if you have a look at this recent thread there may be something there that can help.
Jojo
31-08-2010 6:08 PM
02-09-2010 4:41 PM
