Issues tonight?
- Issues tonight?
- « Previous
- Next »
Re: Issues tonight?
25-04-2012 10:58 PM
Wednesday Night just before 11pm, speeds slow, again. Copper
Normally 17mb/s+
Note, all online times an hour out !!
London Server
However, locally, Manchester...
Birmingham
London speed dropped again !
Re-checked London speed
Re-checked Manchester speed, still high (normal)
I appreciate it is a BT problem, not a PlusNet one, but PN have better tech tools than I have !
Re: Issues tonight?
25-04-2012 11:14 PM
Re: Issues tonight?
25-04-2012 11:20 PM
Re-checked London
Re-checked local Manchester
Speedtest normally defaults to London, and measures 17mb/s+, just checked previous readings.
I rang PN, 11:30pm, they suggest a router re-set.
But I have been getting good speeds for days now via London, apart from Tuesday evening !
As I am using the web now for simple stuff, I'll wait till the morning, and re-set then if measured London speeds are stil low.
Tested a different server down South ( bypassing London ?)
Bournemouth, way down South
London appears to be slow, for some reason.
And the majority of the Olympics events are being held in ............. LONDON !
BT reserve backup circuit
Re: Issues tonight?
26-04-2012 12:42 AM
Re: Issues tonight?
26-04-2012 3:24 AM
Re: Issues tonight?
26-04-2012 9:14 AM
Quote from: PlusComUK Noticed a software update was downloading very slow.......
Software updates are very likely to be slowed down as per the traffic management on your account type.
If it's only the London server that's showing the slow speed, and all others are normal then surely it's that speedtest server having the issues?
Re: Issues tonight?
26-04-2012 9:21 AM
Olympics will mostly be in the London area
Appreciate that is out of your control.
And only late evening ?
Or the circuit between the Midlands and London ?
Re: Issues tonight?
26-04-2012 11:11 AM
Ex-Broadband Service Manager
Re: Issues tonight?
26-04-2012 12:09 PM
Re: Issues tonight?
26-04-2012 4:50 PM
Quote from: Anotherone @houlton23
Does any streaming run faster than that anyway? If so can you enlighten me?
It seems to vary, for example in the iPlayer Diagnostics I just ran, one was limited to 10Mbps, and the other two were limited to 20Mbps (Netmeter graph) - there's nothing in the rate limit table for Extra Fibre that is rate limited to 20Mbps, so not sure what's going on there.
Whenever I 'stream-rip' from iPlayer (kind of downloading the streams, which end up in the streaming queue, rather than the download server queue which is traffic managed - see this, they normally come down at 10Mbps, however I have noticed that if I set off another 'stream-rip' at the same time, it will go at 10Mbps aswell as the other download, making 20Mbps total. I haven't tested this in any real depth so can't confirm it is repeatable.
Alex
Re: Issues tonight?
04-05-2012 12:15 AM
- « Previous
- Next »
