Is this very common?
- Is this very common?
13-06-2010 4:25 PM
ADSL Link Downstream Upstream
Connection Speed 15313 kbps 883 kbps
Line Attenuation 28 db 7 db
Noise Margin 1 db 10 db
Just asking out of curiosity, I have never seen the noise margin this low before although everything seems to be working ok.
Router is a Neatgear DG834G v3
Been running routerstats for 20 mins and the noise margin has been steady at 1db, just how much if any margin do you need?
Len
Message 1 of 2
(570 Views)
1 REPLY 1
Re: Is this very common?
13-06-2010 9:34 PM
I've got the same model, and it is apparently notorious for not reporting noise level correctly. I've had mine show negative numbers before now.
Message 2 of 2
(254 Views)
