Is this delay in removing the 0808 facility normal.
- Re: Is this delay in removing the 0808 facility no...
25-04-2008 9:57 AM
Received this email this morning
Note the date the fault was closed
Quote The fault you raised using the Broadband Fault Checker has been closed on 02/11/07. As your fault is fixed, the 0808 free dial number for your account has been removed.
Message 1 of 7
(1,355 Views)
6 REPLIES 6
Re: Is this delay in removing the 0808 facility normal.
25-04-2008 10:12 AM
Seems reasonable to me, its well within 6 months.
Sounds like somebody has been doing some housekeeping, in the past its been taken away from me almost straight away when the fault has been closed.
Message 2 of 7
(553 Views)
25-04-2008 12:59 PM
Seems like it indeed, as I had a similar email yesterday too.
I'm just curious to know why it's taken this long for the component refreshes/email notification to take so long!!!
Message 3 of 7
(553 Views)
25-04-2008 1:16 PM
Hmmm, not sure why you've received that but Mand's had one too. I'm going to take a look into it now and raise a problem if needs be.
Message 4 of 7
(553 Views)
26-04-2008 12:42 AM
Also had a referral contact me today with an email from PN about losing her 0808 friaco account back in September. 3 hours later, her account died altogether.
Message 5 of 7
(553 Views)
28-04-2008 9:54 AM
Any hint of an update on what happened here Bob?
Message 6 of 7
(553 Views)
29-04-2008 12:54 PM
Looking into this, I think I've figured this out. When the fault checker is instigated the 0808 number is added to the account as backup access. We then follow the fault through and raise to BT where necessary, once we receive notification that the fault is resolved from BT the 0808 number is removed. However in the instances I've seen of this so far the faults weren't actually raised to BT and were just closed as normal tickets. Therefore I worked out the dates from when the fault was raised up until when the 0808 number was removed, they were all around 180 days (give or take 7 days).
I'll see if I can confirm this and get back to you.
Message 7 of 7
(553 Views)
