Is there any point in raising a fault
- Is there any point in raising a fault
25-10-2011 1:40 PM
This is not a dig at Plusnet but a serious question.
I have a problem where occasionally my line will resync with a very low upstream speed as shown from the log below when the phone rings and isn't picked up quickly
Thu 20 Oct 2011 17:28:06 81.174.168.118 Rx-Noise=4.7 Tx-Noise=23.0 Rx-Sync=4928 Tx-Sync=448
Thu 20 Oct 2011 17:38:09 81.174.168.118 Rx-Noise=7.1 Tx-Noise=8.0 Rx-Sync=4480 Tx-Sync=128
Thu 20 Oct 2011 17:48:06 81.174.168.118 Rx-Noise=6.9 Tx-Noise=8.0 Rx-Sync=4480 Tx-Sync=128
Thu 20 Oct 2011 17:58:06 81.174.168.118 Rx-Noise=6.3 Tx-Noise=23.0 Rx-Sync=4640 Tx-Sync=448 (manual resync)
Mon 24 Oct 2011 13:10:33 81.174.168.118 Rx-Noise=5.9 Tx-Noise=23.0 Rx-Sync=4640 Tx-Sync=448
Mon 24 Oct 2011 13:20:33 81.174.168.118 Rx-Noise=6.8 Tx-Noise=6.0 Rx-Sync=4672 Tx-Sync=192
Mon 24 Oct 2011 13:30:33 81.174.168.118 Rx-Noise=6.1 Tx-Noise=14.0 Rx-Sync=4896 Tx-Sync=448 (manual resync)
Mon 24 Oct 2011 13:40:34 81.174.168.118 Rx-Noise=6.6 Tx-Noise=7.0 Rx-Sync=4672 Tx-Sync=192
Mon 24 Oct 2011 13:50:34 81.174.168.118 Rx-Noise=5.9 Tx-Noise=23.0 Rx-Sync=4928 Tx-Sync=448 (manual resync)
I just carried out a series of tests while monitoring what is happening to the upstream error rate with routerstats
Test 1 - ADSLNation Faceplate and Speedtouch pigtail filter in series with only the BT answering machine connected - corrected errors on the upstream increased while it was ringing
Test 2- As above but with only a standard wired phone connected - corrected errors on the upstream increased while it was ringing
Test 3 - As above with no phone connected - corrected errors on the upstream increased while it was ringing
Test 4 - ADSLNation Faceplate only - repeated tests 1, 2 and 3 - corrected errors on the upstream increased while it was ringing
Test 4 - Using test socket with Speedtouch pigtail filter with no phone connected - corrected errors on the upstream increased while it was ringing
If a fault is reported would BT accept it and, if they do, would they accept the evidence of upstream errors as a fault which needs to be corrected
Message 1 of 3
(718 Views)
2 REPLIES 2
Re: Is there any point in raising a fault
25-10-2011 2:10 PM
Every time it happens you have a low upstream snr, already posted in another thread but I have seen similar problems if my upstream in my case drops to 8 or less, a manual reboot during the day resets the upstream snr to 15+ and sync to 440. so once its 10+ its stable for the most part but if it hits 8 I will lose connection and suffer a drop in both down and up IP profiles.
I am beginning to wonder if its this new system BT is running as my exchange has been ADSL2+ enabled for a while, but the day they switch to the new Improved IP profile system I started having issues.
FTTP 500 regrade from Tues 28th November
Message 2 of 3
(309 Views)
25-10-2011 2:38 PM
Hi Jim, not sure how it would be treated faults-wise, but can't see any harm in seeing what they think about it.
Jojo
Jojo
Message 3 of 3
(309 Views)
