Is there a problem at the moment? [SOLVED]
- Re: Is there a problem at the moment? [SOLVED]
03-10-2007 5:28 PM
Hello,
This is difficult as I've just built a new system so I don't know where the problem lays.
The problem is that web pages are either not loading fully, not loading at all, always waiting for something to transfer etc. Sometimes I refresh the page or click the link again at it's there in an instant. This happens on any site even google. If no-one else is experiencing this then it must be my system I suppose, though I've no idea what.
Thanks for any help.
Message 1 of 4
(1,482 Views)
3 REPLIES 3
03-10-2007 6:04 PM
I had this problem wen I had a Time Computer, it was the RAM, You can try removing the RAM and use a peas of paper to clean the contacts.
Warning
Make shore you ground your self, or you will fry your RAM.
Message 2 of 4
(432 Views)
04-10-2007 3:35 PM
I sorted it out, it was the kerio/sunbelt firewall causing the problem. I uninstalled this from my old system a while ago because it was giving me a blue screen randomly. I thought I'd try it again in my new system, but now I've uninstalled it for the last time. I found a free firewall called comodo which had some good write-ups and it seems to be okay at the moment. I don't really need a firewall behind my router but I'd like to keep an eye out for outbound traffic.
Sorry, why am I telling you all this?
Anyway, the problem is solved.
Message 3 of 4
(432 Views)
04-10-2007 4:14 PM
Watt OS do you have?
If you have windos XP you need to tern off the XP firewall. The XP firewall will conflict with your firewall.
I yews:
AVG Anti-Virus.
Zone Alarm Firewall.
AVG Anti-Spyware.
Best of all, they ar all Free.
I yews:
AVG Anti-Virus.
AVG Anti-Spyware.
Message 4 of 4
(432 Views)
