Is the PN network standing up to the Unlimited onslaught?
csogilvie
Re: Is the PN network standing up to the Unlimited onslaught?
You are currently connected to the gateway known as ptw-ag01.
My pings look more than normal...
[cso@lamda ~ $] ping www.bbc.co.uk
PING www.bbc.net.uk (212.58.246.95) 56(84) bytes of data.
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=1 ttl=56 time=23.0 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=2 ttl=56 time=22.4 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=3 ttl=56 time=22.7 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=4 ttl=56 time=22.5 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=5 ttl=56 time=23.6 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=6 ttl=56 time=23.6 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=7 ttl=56 time=22.8 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=8 ttl=56 time=22.7 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=9 ttl=56 time=23.9 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=10 ttl=56 time=23.9 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=11 ttl=56 time=26.0 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=12 ttl=56 time=22.8 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=13 ttl=56 time=23.4 ms
64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=14 ttl=56 time=22.7 ms
[64 bytes from bbc-vip016.cwwtf.bbc.co.uk (212.58.246.95): icmp_req=15 ttl=56 time=22.7 ms
--- www.bbc.net.uk ping statistics ---
15 packets transmitted, 15 received, 0% packet loss, time 14017ms
rtt min/avg/max/mdev = 22.496/23.301/26.048/0.887 ms
MrRichThomas
I'm on ptn-ag02, came in here to see if there was anything going down as my speeds are bad tonight and my ping graph isn't looking to clever.
Strike
What speed do you guys get when you download from FTP server (externally)?
I am getting very random download speed every second between 50KB/sec to 120KB/sec
Also downloading from SSH (using WinSCP) - I get less than 1KB/sec !
csogilvie
I'm currently downloading ftp://ftp.mirrorservice.org/pub/fedora/linux/releases/18/Fedora/x86_64/iso/Fedora-18-x86_64-DVD.iso as a test for you at 1.4MB/sec according to Firefox.
houlton23
Same download here, seeing around 1MB/s although it is varying wildly betwen ~400KBps and 1.5MBps
CX
Quote from: cso
Average of around 3.5MB/sec here, on ptw-ag01.
tijara33
Fixes: 6
It's horrible tonight on ptn-ag02.
Speeds are nearly halved.
Strike
Quote from: cso
Is 1.4MB/sec always normal for you?
Im getting 120KB/sec from that link Sad
I normally get full max speed from other ISP provider when i was on 20 Mbps package (none fibre)
Oxslow
I am on ptw-ag01 I normally get a ping of around 30ms now I am getting a 160ms+ ;( makes it really noticeable in game when your ping is over 200ms.
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    13 ms    13 ms    14 ms  lo0-central10.ptw-ag01.plus.net [195.166.128.195
  3    16 ms    16 ms    16 ms  link4-central10.ptw-gw02.plus.net [84.93.248.6]
  4  162 ms  149 ms  149 ms  xe-0-2-0.ptw-cr02.plus.net [212.159.1.18]
  5  147 ms  148 ms  151 ms  72.14.223.32
  6  135 ms  141 ms  163 ms  209.85.252.188
  7    23 ms    26 ms    15 ms  209.85.253.92
  8    24 ms    21 ms    39 ms  72.14.232.210
  9    24 ms    24 ms    25 ms  216.239.43.233
10    22 ms    24 ms    23 ms  209.85.250.163
11    *        *        *    Request timed out.
12    96 ms    92 ms    93 ms  wi-in-f94.1e100.net [173.194.67.94]
Edit: and what is really annoying is that I spend £5 a month on the pro add on not to have these problems with latency. gggrr
csogilvie
Quote from: Strike
Sorry, yes, I should have said that I'm on ADSL2+ (can't get Fibre here!)
Current line speed:
    16.8 Mb
according to the portal
VileReynard
Fixes: 20
Quote from: Strike
Quote from: cso
Just tried the above link [on fibre] - I seem to be getting only 2MB/sec (top speed on exceptional sites is 8MB/sec).
houlton23
ITWorks
Fixes: 9
Its really bad for me tonight to, , i am connected to pcl-ag03
In the day i get about 6.5mb , silmar upload and a 55 - 58 ping
I hope things improve , and this is not a sign of things to come.
Regards
Mike
Kelly
Fixes: 9
Yep Sad  It's come back!
Try a reboot and get on PCL-AG01, 02, 05, 06, 07, 08 or PTW-AG03, 04  PTN-AG03, 04
Kelly Dorset
Ex-Broadband Service Manager
shuffle
Hiya
Im on unlimited and I dropped the Pro Add on, having upgraded from Value Fibre.
My pings are much higher in the evening (play Battlefield online) which im not happy about, hope this is temporary glitch? Do I need to reset my router.
