Is my router done for?
- Is my router done for?
- « Previous
- 1
- 2
- Next »
Re: Is my router done for?
04-07-2008 9:06 AM
Try it out (from the master socket) if it does not work return it under the distance selling act.
Job done.
04-07-2008 9:34 AM
04-07-2008 9:47 AM
Yes I am sure that returning one will work as long as it is in its packaging and you just say it is no longer required. I will have a think.
04-07-2008 11:39 AM
• goods made to the customer's specification;
• perishable goods (flowers, fresh food);
• CDs, DVDs, and tapes with software, audio or video if unsealed;
• newspapers and magazines;
• betting, gaming and lotteries
04-07-2008 11:49 AM
04-07-2008 11:54 AM
I think you find if he bought it from the plusnet shop he would be able to return it.
Does the plusnewt shop still exist.
04-07-2008 11:58 AM
I think it might even be longer than that!
04-07-2008 12:02 PM
04-07-2008 3:26 PM
My Master socket does not have a testing thingy in. I thought of someone who might be able to mail me a spare router to try, I am just waiting to see if they have one.
04-07-2008 3:54 PM
Also, is your phone line quality OK?? DO you have cracking on voice calls etc. Try the quiet line test, dial 17070 and select option 2, and if you hear any popping/cracking then you can raise a voice fault directly to BT, and this may cure the sync fault at the same time.
If James is feeling nice, he may well sort an engineer vist out for you if it comes to it.
04-07-2008 4:05 PM
Also, liberally applying tea and biscuits is a very good way to get an NTE5 installed - I've certainly found that the majority of BT engineers will work very well under these types of favourable conditions
B.
04-07-2008 5:57 PM
06-07-2008 11:20 AM
06-07-2008 12:57 PM
If plusnet raise an invoice then yes you can return it within 14 days plusnet are wrong by saying they sell them at a loss so 14day rules don't count.
example pcworld sell some computers as a loss leader they don’t say we made a loss so you can’t have a refund. Asda sell digital camera at a loss leader and they don't say no refund
puddy
even digi dave selling routers at £1.36 said I am still covered by the distance selling rules
15-07-2008 4:02 PM
Just to let you know the problem is resolved. It was because I had pressed the reset button on the back of the router so i wiped out all of the settings and after the ISP problem was resolved, I could not get back online. Thanks to all who offered advice.
- « Previous
- 1
- 2
- Next »
